  3. Everything You Need to Know About MSC Nastran 2026.1
Cadence MSC Software
MSC Nastran
MSC Software
CAE
FEA
25 Jun 2026 • 3 minute read
If you want your engineering team to get the most out of your simulation tools, MSC Nastran 2026.1 is a release worth paying close attention to. Whether your team is working through complex nonlinear contact problems, pushing topology optimization toward manufacturable designs, or running large-scale HPC jobs, this update delivers targeted improvements that reduce bottlenecks at every stage of the simulation workflow.
Here's a breakdown of the enhancements we think matter most.
Hybrid Contact in SOL 400: Fewer Setup Headaches, More Robust Results
Contact modeling is one of the most common sources of solver failures and analyst frustration. The new hybrid Node-to-Segment (NTS) method in SOL 400 removes the need to manually define primary and secondary bodies and handles true double-sided contact natively. For complex scenarios like self-contact, large sliding, and stacked shell assemblies, this means a simpler model setup and a significantly reduced risk of convergence failures.
New slip output capabilities add another layer of insight, tracking relative motion, slip rate, and accumulated slip at contact interfaces. For teams analyzing friction, wear, or joint behavior, this is data that may previously have required post-processing workarounds. Now it's built in.
Multi-Part and Manufacturable Topology Optimization in SOL 200 NEO
Two enhancements here work together to make topology optimization genuinely more useful in a product development context.
Multi-part optimization allows multiple design regions to be solved simultaneously within a single model. The traditional sequential approach of optimizing one component, manually accounting for its neighbors, and then iterating could be slow and tended to miss system-level load-path interactions. Solving regions concurrently captures true part-to-part behavior during optimization, producing better designs in less time.
The minimum gap constraint then ensures those designs are buildable. By enforcing minimum feature spacing directly within the optimization loop, it closes the gap between what the solver proposes and what manufacturing can actually produce. Fewer redesign cycles at the back end of the workflow.
Amplitude-Dependent CBUSH Elements: Capturing Real-World Dynamic Behavior
Bushings, dampers, and isolation systems don't behave linearly with respect to amplitude, but simulation models have historically treated them as if they did. The new amplitude-dependent CBUSH capability allows stiffness and damping properties to vary with excitation amplitude at each frequency, aligning simulation behavior with physical test results. For NVH, rotor dynamics, and vibration isolation applications, this level of fidelity directly reduces the number of physical prototype iterations needed to achieve correlation.
ACMS Scalability and Robustness Improvements
For teams running large models on HPC infrastructure, the ACMS enhancements address two practical pain points. Support for mildly indefinite matrices means models that previously failed or required manual intervention now solve more reliably, which is an important quality-of-life improvement when job failures are costly in both time and compute resources.
Improved memory management and more efficient superelement processing mean larger models can run within existing infrastructure, with reduced risk of memory-related failures and smaller output files. Less time babysitting jobs means you can spend more time interpreting results.
Convergence and Performance Gains in NLPERF
The new stiffness update in SOL 400's high-performance nonlinear solver intelligently balances full and modified Newton-Raphson iterations. The practical effect is faster convergence on close-to-linear problems without sacrificing robustness on genuinely nonlinear ones. Enhanced convergence monitoring, including energy and work history output and logarithmic visualization, gives analysts better real-time visibility into solver behavior, enabling earlier intervention before a run goes off the rails.
The Bottom Line for Engineering Teams
MSC Nastran 2026.1 is a release focused on reducing the friction that slows simulation teams down: contact model failures, unmanufacturable optimization results, HPC job instability, and inaccurate dynamic models. At Cadence, we see these improvements as directly supporting faster design cycles, better upstream decision-making, and fewer costly late-stage surprises. If your team hasn't yet evaluated this release, now is the time.
Don't miss the full list of everything included in this release over at SimCompanion!
