  3. Fewer FEA Frustrations: A Smarter Way to Debug MSC Nastran…
Cadence MSC Software
MSC Nastran
PSDA
SDA
CAE Software
Fewer FEA Frustrations: A Smarter Way to Debug MSC Nastran Models
18 May 2026 • 2 minute read
If you've spent hours hunting down a mysterious solver error or scratching your head over perplexing results that don't quite match your expectations, you're not alone. Debugging FEA models is one of the most time-consuming parts of any simulation workflow. Luckily, it doesn't have to be a source of frustration.
A new white paper from the MSC Nastran experts lays out a practical, no-nonsense roadmap for catching and fixing the most common FEA errors before they derail your analysis, so you can trust your results and spend a little less time yelling at your screen.
Want to skip the summary and go right to the white paper?
Mastering FEA Analysis: A Practical Guide to Debugging Using MSC Nastran
Start with the Model, Not the Results
Something every analyst knows to look for but sometimes skips under deadline pressure is geometry and model validation. MSC Nastran's built-in GEOMCHECK capability goes beyond what most pre-processors catch, flagging issues like poor aspect ratios, excessive skew angles, and surface warping. The key insight here is that elements that look fine in pre-processing can still fail solver tests, so running GEOMCHECK before you submit is a good time-saving practice.
FEMCHECK is also particularly useful if your model is heavy on RBE elements (and let's be honest, most industrial models are). Having too many RBE3 elements with excessive independent legs can quietly inflate your solve times without improving accuracy. FEMCHECK can not only flag these issues but also automatically trim unnecessary RBE3 legs. Just running this check alone reduced elapsed solve time by 4.2x in one example we've demonstrated. That's the kind of speed-up that can shave hours off your work day and give you more time to refine your designs.
Are You Accidentally Grounding Your Model?
One annoyance that will ring familiar for many engineers is unintentional grounding, which can be one of the sneakiest sources of misleading results. The GROUNDCHECK feature in MSC Nastran attempts to move your model as a rigid body in six directions, checking whether it can do so without generating artificial strain energy. If it can't, something in your constraints, connectivity, or element definitions is holding it in place when it shouldn't be. The paper offers clear guidance on interpreting the output and efficiently tracking down the culprit.
Mass Properties, Singularities, and Missing Materials
You'll also learn to tackle some of the practical headaches: incorrect mass units corrupting your dynamic results (WEIGHTCHECK helps here), missing material properties in large models (MODEL_CHECK can fill gaps temporarily so you can keep moving), and grid-point singularities that prevent the stiffness matrix from inverting cleanly (AUTOSPC to the rescue).
The Bigger Picture
What ties all these debugging tips together is a simulation philosophy that helps you build disciplined pre-solve habits, use the diagnostics MSC Nastran already gives you, and treat warnings as useful information rather than noise to click past.
If any of this sounds familiar, or if you want the full walkthrough with specific commands, output examples, and tips, the complete white paper is worth the read.
Download the full white paper to get every command, parameter, and practical tip covered in detail.
