  3. How Actran 2026.2 Opens Up Powerful New Acoustic Simulation…
MC202605188636
MC202605188636
Actran
Acoustic Simulation
acoustics
FEA
CAE Software
How Actran 2026.2 Opens Up Powerful New Acoustic Simulation Capabilities
16 Nov 2026 • 3 minute read
For simulation managers and product leaders, noise and vibration performance is no longer a late-stage checkpoint. It shapes brand perception, regulatory compliance, and customer satisfaction. Yet many teams still rely on structural CAE tools that treat acoustics as an afterthought, or use fragmented, manual processes that aren’t equipped to handle the complexities of acoustic simulation. Actran is the most comprehensive acoustic simulation tool available, and the updates in Actran 2026.2 provide many enhancements to speed up acoustic workflows, more accurately predict acoustic performance, and take advantage of the latest GPU technology from NVIDIA.
Faster Solves with NVIDIA GPU Acceleration
Slow simulation runs can lead to bottlenecks in product development. For faster time-to-solve, Actran 2026.2 integrates NVIDIA cuDSS, a CUDA-X library for accelerating sparse direct solving on GPUs. It supports direct frequency-response, green, pellicular, and equivalent-boundary-condition analyses, with significant reductions in factorization and back-transformation times, enabling the most computationally intensive portion of the simulation workflow to run on GPUs. It works with NVIDIA GPUs from the NVIDIA Pascal architecture through the latest generations, including Ampere, Hopper, and Blackwell, so teams can benefit from hardware they already have access to. Support for the Cadence Millennium M2000, equipped with an NVIDIA RTX PRO 6000 Blackwell Server Edition GPU, opens up a new high-performance computing option.
Fewer Tools, Less Manual Work
The new Ffowcs Williams–Hawkings workflow delivers end-to-end far-field noise prediction from porous CFD surface data in one guided environment. It automates field mapping, spectral analysis, and FWH integration, replacing a manual process that previously required multiple tools. It automatically detects CFD field names and configures the Fourier transform parameters, which lowers the risk of setup errors and shortens the learning curve for aeroacoustics and CFD engineers working with ProLB data.
A new multi-layer meshing wizard also simplifies trim analyses and multi-layer wall modeling, such as aircraft structures, by generating encapsulated tetrahedral meshes with independently defined layer thicknesses and mesh sizes.
Better Accuracy Where It Matters
Accurate simulations mean engineers have more confidence when making virtual design decisions. The new hybrid FE–SEA formulation for fluid-structure coupling in Virtual SEA accounts for all structural and fluid modes. It is now the default method, improving accuracy without sacrificing performance. In radiosity, atmospheric damping can now be modeled for large, open models, for both interior and exterior propagation.
The radiosity solver also supports atmospheric damping on surrounding fields and pressure excitation on panel components, converting measured or simulated surface pressure, such as side-mirror wind noise, into equivalent injected power. Teams can model exterior-to-interior transmission without explicitly modeling the external acoustic field.
Broader Coverage for Modern Products
Loudspeaker boundary conditions are now available in the pass-by and AVAS workflows, supporting electric potential, displacement, velocity, and acceleration. This is especially relevant for electric vehicle programs. The damping pad positioning workflow now accounts for air-borne as well as structure-borne loading. This simplifies exterior-to-interior noise transmission modeling and improves the panel design where acoustic loading analysis for large, open models where exterior damping can’t be ignored.
Smoother Day-to-Day Experience
Smaller improvements add up to a much more user-friendly experience that improves efficiency across the team. A new WM space sequence stores modal quantities only where needed, improving performance by default. The coupling surface definition for radiation analyses has been replaced with a simpler domain-based setup, and legacy models convert automatically. The mesh editor now includes all meshing tools. The built-in "Report a Problem" and "Make a Suggestion" actions in ActranVI and related tools make it easy to send structured feedback directly to Cadence.
Why Actran 2026.2 Is Worth the Upgrade
Actran 2026.2 helps your team deliver more reliable acoustic predictions earlier in the design cycle, with less manual effort and faster turnaround. For managers focused on productivity, hardware investment, and product quality, it offers a clear upgrade path.
Ready to see it in action? Contact your Cadence representative to learn how Actran 2026.2 can fit into your simulation workflow.
