  3. Putting Digital Engineering Into Practice
SableBender
SableBender
physical systems simulation
Digital Twins
18 Nov 2026 • 1 minute read
The Department of War has made its direction clear: digital engineering is becoming fundamental to how defense systems are designed, developed, tested, manufactured, and sustained. DoDI 5000.97 formalizes that direction, calling for digital engineering ecosystems that use digital models, digital threads, and digital twins throughout the system lifecycle.
The objective is not simply to create digital representations of physical systems, but to establish authoritative, connected sources of engineering information that can support decisions across the lifecycle. For defense organizations, the challenge now shifts from adopting digital engineering to operationalizing it.
That requires more than adding new tools to existing workflows. It requires an engineering environment where models can be trusted, reused, connected, and continuously evaluated as systems evolve.
Digital Engineering Framework
The January 2026 Digital Engineering information sheet builds off of the 2023 Digital Engineering strategy.
Establishing an Authoritative Source of Truth
Cadence, including capabilities developed through MSC Software, brings together system modeling, high-fidelity simulation, engineering data and digital-twin technologies across the engineering lifecycle. Our portfolio enables engineers to model system behavior, apply physics-based analysis to validate designs, and evaluate performance throughout development and beyond the physical test environment.
That combination enables defense organizations to move beyond isolated simulations and models toward a more connected engineering environment and an authoritative source of engineering truth—one where multidisciplinary analysis can inform design decisions, simulation can reduce physical iteration, and operational evidence can feed back into engineering.
For defense organizations, digital engineering is becoming more than a development methodology. Organizations that can establish an authoritative source of engineering information by connecting models, simulation, and engineering data will be better positioned to move from insight to action, reduce costly physical iteration, and respond faster as systems, requirements, and production environments change.
We help defense organizations build that connected engineering foundation, bringing together system modeling, simulation and digital-twin capabilities to turn engineering data into actionable insight.
Abstract visualization of engineering information converging into a trusted digital foundation, representing an authoritative source of truth for digital engineering and decision-making.
Explore how Cadence can help advance your digital engineering strategy and connect engineering insight to mission-critical decisions.
