  3. The Digital Thread Needs a Digital Twin
SableBender
SableBender
digital thread
supply chain
Digital Twins
manufacturing
17 Nov 2026 • 4 minute read
How Digital Twins Turn Defense Manufacturing Data Into Action
Defense manufacturers are under increasing pressure to do more than build complex systems. They need to design, manufacture, qualify, deliver, and sustain those systems faster—while maintaining the traceability and quality that defense programs demand. The Defense Business Board has described digital twins as part of a broader digital ecosystem.
For manufacturers that have already invested in simulation, digital twins, and connected engineering environments, the opportunity is to take the next step: connect those capabilities through a digital thread and make the resulting data work across the lifecycle.
Abstract visualization of a digital twin connected to lifecycle data through a digital thread, showing continuous feedback between engineering, manufacturing, quality, and operational information.
Connecting the Defense Manufacturing Lifecycle
A digital thread establishes continuity across the product lifecycle, connecting requirements, engineering, manufacturing, quality, supply chain and sustainment. The value is not simply having data from each stage, but maintaining the relationships between that data as the product evolves.
That means an engineering change can be traced to its manufacturing impact, inspection requirements, and downstream performance. Manufacturing and quality data can be fed back into engineering. And the configuration and history of an individual component can remain connected from design through production and into sustainment.
For defense manufacturers, that continuity creates the foundation for more rigorous traceability, faster feedback loops, and better-informed decisions across the lifecycle. The Department of War is already treating digital thread and digital twin technologies as complementary pieces of a more connected manufacturing enterprise. Likewise, NIST's digital thread research similarly emphasizes connecting as-designed, as-planned, as-executed, and as-inspected information rather than leaving those views in separate systems.
The Digital Twin Makes the Thread Actionable
For many defense manufacturers, digital twins are already part of the engineering and manufacturing toolkit. The next opportunity isn't simply creating a more detailed twin. It's connecting the twin to the broader digital thread so it can draw on—and contribute to—information across the product lifecycle. The Defense Business Board has described digital twins as part of a broader digital ecosystem.
Instead of using simulation primarily to validate a design or optimize an individual process, manufacturers can begin connecting engineering models with manufacturing conditions, quality data, test results, and operational information. The result is a more complete picture of how changes propagate through the system.
A machine shop might use a digital twin to understand how process variations affect quality and production consistency. A subsystem manufacturer could connect engineering and manufacturing data to reduce qualification risk. A prime contractor might use digital twins to evaluate the impact of design changes across multiple programs and facilities. The scale differs, but the underlying objective remains the same: use connected information to make better decisions earlier.
That can unlock questions such as:
  • If a material, tolerance, or manufacturing process changes, what does that mean for downstream performance?
  • If production data shows increasing variability, can engineering models help identify its potential impact before it becomes a quality or reliability problem?
  • If a design is modified, can the same digital environment evaluate manufacturability, performance, and test requirements together?
  • If a process is moved or replicated at another facility, what data and process parameters need to follow it to achieve equivalent results?
  • As field and sustainment data comes back, how can it inform the models used for the next design or production decision?
This shifts the digital twin from an isolated engineering asset to a connected part of the lifecycle—where the digital thread provides context and the twin turns it into actionable insight. For defense manufacturers, that has implications well beyond engineering efficiency. It can help shorten feedback loops, reduce the need for physical iteration, improve manufacturing consistency, and make it easier to carry knowledge from one facility, program, or lifecycle stage to another.
The Department of Defense is already applying this concept. In partnership with Picatinny Arsenal, MxD has deployed digital twin technology to help maintain consistent manufacturing processes, minimize waste and support the rapid scaling of munitions production to other facilities.
The goal isn't simply a better digital twin. It's a digital environment where the information generated throughout the lifecycle can continuously improve what happens next.
Put the Digital Thread to Work
Cadence, including the capabilities developed through MSC Software, brings together high-fidelity simulation, system modeling, engineering data, and digital-twin technologies to connect design decisions with real-world performance.
For defense manufacturers, this means moving beyond using simulation to validate a design at a single point in time. Physics-based models can incorporate manufacturing and operational data to evaluate how a system performs as-built and under changing conditions. Those insights can then inform the next engineering, manufacturing or sustainment decision.
The result is a more continuous lifecycle:
Design → Simulate → Manufacture → Test → Operate → Improve
For an industry focused on increasing capacity, improving resilience, and delivering capabilities faster, this connected approach can help reduce physical iteration, preserve engineering knowledge, improve manufacturing consistency, and accelerate feedback across the lifecycle.
Defense manufacturers have already invested in digital engineering, simulation and digital twins. The next opportunity is to connect those capabilities—and turn the data they generate into better decisions.
digital twin classifications
Digital Twins Classification
Learn how Cadence can help connect your digital thread, extend the value of your digital twin, and accelerate the path from engineering insight to production.
