  3. The Top Five Reasons to Use Cradle CFD 2026.1
Cadence MSC Software
CFD
MSC Software
Cradle CFD
15 Jul 2026 • 2 minute read
If you’ve been weighing whether it’s time to upgrade your CFD software, Cradle CFD 2026.1 makes a very strong case for taking the time and effort to update. This release introduces new physics, new hardware pathways, and new workflow efficiencies that directly affect throughput, cost, and product quality. Here are the top five reasons this upgrade deserves a place on your product development roadmap.
1. Multi-GPU Simulation Without the Memory Ceiling
A big update in this release is GPU-native computing in scFAST. Simulations can now scale across multiple GPUs in a single run, removing the memory limits of the previous release. Direct GPU-to-GPU communication adds a further performance boost, and the new architecture supports the latest Blackwell GPUs, with rotating domains handled through a fixed-mesh (MRF) approach. For teams under pressure to shorten design cycles, this translates directly into faster iteration and the ability to tackle larger, more complex models without re-architecting your compute infrastructure.
2. New Physics for Laser Welding Accuracy
Manufacturing and process engineering teams working with laser welding now get a meaningful accuracy upgrade. scSTREAM's standard single-phase MARS method has never been able to represent a gas phase, meaning air bubbles trapped in molten metal were effectively invisible to the simulation. A new model based on the adiabatic expansion and contraction of air bubbles changes that, allowing engineers to predict air-pocket formation and tune laser intensity, path, and speed to avoid defects before they happen on the shop floor.
3. A Step Toward AI-Driven Surrogate Modeling
The (currently in beta) AI-powered 3D-ROM capability in ODYSSEE lets users treat mesh point coordinates as parameters when generating reduced-order models, enabling surrogate models to account for geometry changes, not just operating conditions. A glider wing that deforms under load, for instance, can be represented in a surrogate model that predicts performance across that deformation. For product leaders exploring digital twins or real-time design exploration, this is an early but important building block toward AI-augmented engineering workflows.
4. Native Linux Post-Processing on the Cluster
The new headless scPOST module runs directly on Linux-based HPC systems, eliminating the need to download massive results files just to generate a report. Post-processing can now be performed as a batch export directly from the simulation cluster or from remote storage. This is a meaningful efficiency win that translates to less data movement, less wasted engineer time, and faster turnaround from simulation to decision.
5. Broader Workflow and Accuracy Gains Across the Board
Beyond the headline features, 2026.1 delivers a set of practical improvements: an scSTREAM FMI 2.0-compliant co-simulation with more flexible variable support, a non-equilibrium solidification and melting framework for more physically accurate multiphase results in scFLOW, meshing improvements in scFLOWpre for faster model setup from imported meshes, and dynamic electric current calculations in scSTREAM that cut computation time by 35% without sacrificing accuracy.
A Forward-Looking Approach to CFD
Cradle CFD’s development team is investing in both raw performance and forward-looking capability. For simulation managers focused on throughput and for product leaders focused on innovation velocity, Cradle CFD 2026.1 offers a compelling reason to upgrade now and plan to incorporate future updates as they release to keep on top of the latest improvements in speed, robustness, and efficiency.
Learn more about all the updates to Cradle CFD over at SimCompanion.
