  3. Your Mesh Is Not the Problem. Rebuilding It Twelve Times…
Veena Parthan
Veena Parthan
CFD
Automotive
physical systems simulation
ANSA
CAE
Your Mesh Is Not the Problem. Rebuilding It Twelve Times Is
24 Nov 2026 • 4 minute read
The geometry change landed last night: a revised bracket, two new mounting holes, a different bolt spec on the rear subframe. The solver will get through the run in a few hours. Getting the model ready to submit will take most of the week, because the mesh from the last iteration cannot be updated. It has to be rebuilt for the twelfth time on this program.
Volvo Cars Corporation stopped doing that for one of the most repetitive parts of the rebuild. Engineers at the Volvo Cars Safety Center built an ANSA Fastener library in which every standard part, from bolts to rivet nuts, carries its CAD and its solver-specific FE representations. For a new-release model, they select the correct entry rather than remodeling it. Replacing and adjusting fasteners now takes about five minutes, compared with the hours it used to take. The fasteners did not get simpler. The work is captured once and then re-run, not redone.
Figure 1: The standard-parts library Volvo Cars built in ANSA. Each entry, from bolts to rivet nuts, holds its CAD and solver-ready FE representations, so engineers select the correct one rather than remodeling it.
That distinction matters more than it used to. Solvers now run orders of magnitude faster. The bottleneck is no longer the solving part itself, but the hours spent before and after it. The eBook The CAE Automation Playbook shows how engineering teams reclaim those hours, one workflow stage at a time, with a measured result for each.
Capture the Meshing Procedure, Not Just the Mesh
A repeatable meshing procedure records the decisions an analyst would otherwise make by hand: which features to simplify, where to refine the mesh, and what counts as an acceptable element. The ANSA Batch Mesh Manager performs automatic feature recognition and defeaturing, enforces user-defined quality criteria such as skewness, aspect ratio, and minimum length, and runs different meshing treatments on different regions of a model.
It then applies that same recipe to new geometry through part and property name filtering, so a meshing standard set once is reused across parts and across projects with predictable results. A mesh built from a captured procedure is reproducible, turning a design change from a multi-day rebuild into a simple re-run.
Classify Every Part Before It Is Meshed
ANSA’s ML-based part-type detection sorts every part, from sheet metal to castings and fasteners, and routes each to the right meshing path. On one EV battery and floor assembly, it classified more than 2,000 parts with no manual tagging.
Once ANSA identifies the part type, the next decision is how to represent it. For thin parts with roughly uniform wall thickness, such as sheet-metal stampings, Skin function extracts the midsurface between the two main faces and carries the wall thickness onto the shell elements. For cast or molded parts with varying wall thickness, Casting function extracts the midsurface and its mesh together so the model captures those thickness changes.
When a casting has regions too thick to model accurately as shells, ANSA detects and marks them automatically. It then builds a hybrid mesh: shell elements for the thin walls and solid tetrahedral elements for the thick regions. Engineers don’t have to sort those regions by hand.
Turn Each Design Change into a Re-Run
The mesh is only one part of getting a revised model ready to solve. In the ANSA Task Manager, a CAE specialist can save the order and settings for meshing, connections, and checks as a template that applies to multiple models. The same template can apply loads and boundary conditions, set up solver controls, run a final integrity check, and export a ready-to-run solver deck.
 At LCFC, the automated workflow identified screws from a database and built couplings by rule, cutting the time to prepare finite element models with complex connectors by 67 percent.
Meshing is one chapter. The eBook also covers the CFD workflow, automated reporting, and DOE, each paired with a result measured by a named engineering team, from Toyota Motor Europe’s 91 percent cut in external-aero pre-processing lead time to Yamaha Motor’s 50 percent reduction in brake squeal man-hours.
Automated reporting helped Stellantis cut crash-analysis reporting from a full working day to under 30 minutes. Download the eBook to see how the same approach applies across your CAE workflow.
References
Volvo Cars Corporation, replacing and adjusting fasteners such as bolts and rivet nuts for a new release model in about five minutes versus the hours the previous approach required, using an ANSA Fastener library built on DM. Quote from Fredrik Fors, Crashworthiness Analysis Engineer, Volvo Cars Safety Center. BETA CAE published case study: https://www.beta-cae.com/pdf/case/volvo_fastener_library.pdf
Batch Mesh in ANSA for automated, high-quality mesh generation across structural and CFD models, demonstrated in the BETA CAE tutorial “Batch Mesh in ANSA: Automate, Accelerate, and Perfect your Mesh”: https://youtu.be/Bb_RjUJ9yME
Middle mesh extraction from casting parts with the ANSA Midsurface tool, demonstrated in the BETA CAE tutorial “Getting started with Middle Mesh Extraction from Casting Parts in ANSA v25.1.x”: https://www.youtube.com/watch?v=WeeU5x8zpWo
LCFC (Hefei) Electronics Technology, laptop-modeling automation tool for FE models with complex connectors, achieving a 67 percent time reduction and an overall 200 percent efficiency increase. Quote from Jiabin Bi, Senior Engineer. BETA CAE published case study: https://www.betacae.com/pdf/case/lcfc-lap-top-feautomation.pdf.
