  2. RF Engineering
  3. Measuring 2-Tone Intermodulation Using Envelope-Following…
Tawna
Tawna
RF
RF Simulation
analog/RF
envelope
RFIC
HB
Spectre RF
spectre spectreRF
RF designer
Analog Simulation
MMSIM
RF Block Simulation
Virtuoso Spectre Simulator GXL
fast envelope
analog
ADE
RF spectre spectreRF
spectreRF
Spectre
RF design
harmonic balance
SpectreRF tutorials
simulation
wireless integrated circuit verification
Measuring 2-Tone Intermodulation Using Envelope-Following Analysis
16 May 2012 • 4 minute read
From time to time, SpectreRF users simulate very large, extracted-view circuits in 2+ tone QPSS. In many of those cases, memory requirements exceed the available resources. When that happens and small-signal approximations aren’t applicable, the user is typically stuck.
The solution below and attached database describe a technique that achieves an order-of-magnitude reduction in memory requirements by converting an N-tone QPSS problem to an equivalent (N-1)-tone envelope-following analysis.
Basic Idea
This is a 2-tone signal in the common HB representation:
We can also look at this as a modulated carrier, with the modulation function:
We run an envelope analysis to compute the modulations at each node and harmonic and calculate the multi-tone representation using DFT.
Motivation:
* Numerically, envelope simulation is similar to HB simulation repeated at each time step.
* By looking at a 2-tone signal as a modulated carrier, we convert a 2-tone problem to many smaller 1-tone problems.
* In general, we can convert an N-tone HB analysis to a series of N-1 tone analyses.
* For very large circuits with huge memory requirements, this can reduce the required memory by an order of magnitude – effectively, the same problem is now computed using much smaller, N-1 tone systems.
Basic Approach in Virtuoso:
* Use a Verilog-A module and transient simulation to generate I/Q components of the 2-tone modulation function
* Apply the I/Q components using the PORT element’s Modulation parameters and run an envelope simulation
* Run envelope analysis over N periods (the period is just the inverse of a half of the frequency spacing); this lets all transients expire (we are looking to reach the envelope steady-state)
* Use adaptive step envelope for best simulation accuracy, but use equally spaced strobe output for best postprocessing accuracy using DFT.
Applicability:
* This currently works with 2-tone simulation.
* This should also work with 3+ tones, but currently does not. CCR 979403 has been filed for this issue. Once fixed, you will be able to apply this to 3+ tones.
* PAC
– just set the power of one of the 2 tones to 0 and the other to something suitably small. In theory, this technique uses less memory than PAC.
Example:
In this example, you wil see:
* Creating the IQ signal
* Running envelope simulation
* Postprocessing
* Results comparison
Use the attached database testcase.tar.gz.   This is available on Cadence Online Support in Solution 11774216.
Open library test_2t_env.
Simulate the cell generate_envelope from state spectre_state1.
Generating the 2-tone Envelope
The ADE setup lets you specify tone spacing, power in each tone, the number of samples per period (N) and the number of periods (cycles) to store.
You get something like this:
This now represents the envelope of our two-tone signal, and we’ll run and envelope analysis with it as the source next.
Verifying the Source Signal
First, we’ll run a very simple example, just to make sure that we get what we expect.
Open the test_port schematic view and observe the port’s relevant settings.
Port Edit Properties form:
Running the Simulation:
Open test_port->spectre_state1 and simulate.
Plot the ‘right’ and ‘left’ outputs: (Note that 'right' and 'left' are defined below).
What are 'right' and 'left'??
* ‘Right’/’Left’ is what you would see to the right/left of the carrier when you look at the spectrum analyzer.
* This is just an artifact of how we post-process the envelope (to be explained later).
* Since the ViVA DFT works on purely real waveforms, ‘left’ is really the image of the negative frequency spectrum.
* So, we have a -20 dBm tone, offset 1 MHz from the carrier, and another of equal power, offset -1 MHz from the carrier. This is exactly what you’d expect.
Running a 2-tone HB Simulation for Reference
Open test_hb_2tone, which is just a behavioral LNA simulation.
Run test_hb_2tone, which is the excitation we saw in the above paragraphs, applied in an HB simulation.
Running an Envelope Simulation on the LNA
Run test_env_2tone->spectre_state1.
This is the same as the previous example, except that uses envelope simulation with the PORT element as set up earlier.
Since the LNA has no memory and the excitation is symmetric, ‘left’ and ‘right’ are the same.
Comparison Summary
HB and envelope give nearly identical results!
Post Processing Background
* To calculate the spectrum, we would ideally take the complex DFT of the waveform and convert to dBm. The formula goes like:
  Spectrum=dbm(DFT(X(t)))
* Since there is no complex DFT in ViVA, we do something like:
  Right Spectrum = dbm(DFT(real(X(t)/2)+j*DFT(imag(X(t)/2))
  Left Spectrum = dbm(conj(DFT(real(X(t)/2)))-j*conj(DFT(imag(X(t)/2))))
* Note that, in all cases, we want to process only the last cycle of the waveform (when the steady-state is reached).
* The expressions are a bit messy. They are shown only for reference below. Use the ADE state as a bench rather than attempting to enter the expression from scratch.
Spectrum Post Processing Expressions 'Right'
(10 * log10((pow(abs(((dft(real(harmonic(v("/out" ?result "envlp_fd") '1)) ((pv("/cycles" "value" ?result "variables") - 1) / pv("/deltaf2" "value" ?result "variables")) (pv("/cycles" "value" ?result "variables") / pv("/deltaf2" "value" ?result "variables")) pv("/N" "value" ?result "variables") "Rectangular" 1 "default") + (sqrt(-1) * dft(imag(harmonic(v("/out" ?result "envlp_fd") '1)) ((pv("/cycles" "value" ?result "variables") - 1) / pv("/deltaf2" "value" ?result "variables")) (pv("/cycles" "value" ?result "variables") / pv("/deltaf2" "value" ?result "variables")) pv("/N" "value" ?result "variables") "Rectangular" 1 "default"))) / 2)) 2) * 10)))
Spectrum Post Processing Expressions 'Left'
(10 * log10((pow(abs(((dft(real(harmonic(v("/out" ?result "envlp_fd") '1)) ((pv("/cycles" "value" ?result "variables") - 1) / pv("/deltaf2" "value" ?result "variables")) (pv("/cycles" "value" ?result "variables") / pv("/deltaf2" "value" ?result "variables")) pv("/N" "value" ?result "variables") "Rectangular" 1 "default") - (sqrt(-1) * dft(imag(harmonic(v("/out" ?result "envlp_fd") '1)) ((pv("/cycles" "value" ?result "variables") - 1) / pv("/deltaf2" "value" ?result "variables")) (pv("/cycles" "value" ?result "variables") / pv("/deltaf2" "value" ?result "variables")) pv("/N" "value" ?result "variables") "Rectangular" 1 "default"))) / 2)) 2) * 10)))
Have fun simulating!
Best Regards,
Tawna
