  2. RF Engineering
  3. Solving RFIC and RF Module Design Issues
Kim Khoury
Kim Khoury
RF
Virtuoso RF Designer
ICADVM18.1
RFIC
Virtuoso Meets Maxwell
Virtuoso RF
RF design
Custom IC
5 Jun 2020 • Less than one minute read
 When creating new RFIC modules, designers typically need an array of tools and applications from various vendors to complete the design process.  In 2018, Cadence launched the Virtuoso® RF Solution to enable designers to create faster designs with better results. A key difference of the Virtuoso RF Solution is you only need a single design environment to create, analyze, and implement designs in a simple and automated way and with minimal expertise required. So what used to take multiple weeks, with the new Virtuoso RF Solution, design time is cut down to a few days with the same accuracy as before.
Learn how to overcome challenges in designing RFIC, RF, and RF SiP modules through our three-day webinar series from June 23-25, 2020. Read our recent Custom IC Design blog post on Thinking Outside the Chip to find out more about the webinar topics or register now.
