  2. AutoMesh
  3. IGG connecting multiple blocks to a common interface for...
  • State Verified Answer
  • Answers 1
  • Subscribers 7
  • Views 14580
IGG connecting multiple blocks to a common interface for Volute meshing
JosephSmith
JosephSmith over 4 years ago
Hi everyone! I am a beginner attempting to mesh a volute in IGG. The cad is seen in image 1. I have also split the CADs surfaces further to attempt to make the blocking process easier
Image 2 below shows an upclose region near the cutwater. At this section, it seemed appropriate to split the mesh into two parts: A and B, extrude them separately and then set full non matching boundary conditions on the patch where they have a common interface.
I tried to extrude the portion of the face B seen below in image 3.
The portion A of the face was then extruded separately in image 4:
The two extrusions next to each other are in image 5:
The last image is my attempt at first trying to split the circular extruded section A into a patch near the common interface of B. Then setting the two patches between A & B's extrusion  to full non matching.
I would like to know if the above process may be incorrect, or if there is a more suitable way of approaching this problem.
I have tried to use methods from the IGG tut 3&4 to tackle the problem but would appreciate a second opinion.
  • Colinda
    Colinda over 4 years ago +2 verified
    Hi Joseph, Based on these images I am wondering whether the patches on the two sides of the full non-matching connection are on a common surface at the location where they should be connected? I suspect…
  • domen
    domen over 4 years ago in reply to Colinda +2
    I agree with Colinda. It seems that the edges are snapped onto a surface different than the one you want to use as a connection between the two mesh blocks. I would also add that the mesh you are going…
  • domen
    domen over 4 years ago in reply to JosephSmith +2 suggested
    I would split the domain into three parts, then use interfaces (FNMB in Igg's lingo) to connect the three regions. 1 outlet conical geometry 2 around the tongue 3 scroll At the tongue, we would…
  • JosephSmith
    0 JosephSmith over 4 years ago in reply to domen
    Hi Domen,
    Thank you for the suggestions.
    I intended to try out both combinations of a structured and unstructured volute combined with a structured impeller, although I have not used FINE Open yet. Ultimately, I intend on parametrizing the impeller blades in autoblade and optimizing the impeller with volute in Design 3D. With cavitation models enabled, I suspect this will be quite long and a harddrive space intensive process.  So I wanted to check the file size comparisons and how much faster using a structured impeller+volute would be in comparison to using the open solver with a structured impeller+ unstructured volute.
