  2. Marine
  3. Fine/Marine solver crash
  • Replies 15
  • Subscribers 8
  • Views 14665
Halder
Halder over 3 years ago
Fine/Marine solver crash after running multiple simulations by using the delay option. kindly help me how to solve this issue.
  • Halder
    Halder over 3 years ago in reply to Andrew Beckett
    @Beckett sir, I am trying to upload a screenshot. But unable to do that. Kindly help regarding this issue.
    I also have some doubts regarding the roughness calculation in the ship. I have simulated a full-scale KCS model, I used different size roughness. But I am not able to act above 500 micrometres. After that, I got the solver crashed. Is there any limitation for roughness size for full-scale ships? I am new in this area. Kindly advise me on how to resolve this issue.
  • Benoit Mallol
    Benoit Mallol over 3 years ago in reply to Halder
    I will ask developers about any limitation about the size of roughness but I am not aware of any limitation so far.
    When you say "solver crashed", do you mean that the solver diverged? There is a difference between a crash (hard stop because of a defect) and a divergence (we see the residuals going up quite quickly).
    I understand from your messages that you succeeded to get results for various simulations under 500micrometers but not above and it diverges above that value. Correct?
    Best regards,
    Benoit
  • Halder
    Halder over 3 years ago in reply to Benoit Mallol
    @Mallol, yes the flow is diverged and indicated solver crash. In addition above 500 micrometer, the flow is diverged.
    I have some doubt calculation regarding sinkage. I follow the KCS model but I am getting positive sinkage but most of literature  mentioned negative  value of sinkage. However, the origin is near stern side of the ship model. please guide me.
  • Benoit Mallol
    We quickly checked on a flat plate and we reproduced the behavior. If we increase the roughness a lot, the flow solver starts to diverge. The issue comes from the "leading edge" (equivalent of the front / bow for a ship). But the simulation converges much better with a lower Y+ (meaning decreasing the first cell size). It works well with Y+=20 and even better with Y+=1.
    This is somehow unexpected, in particular since roughness was implemented for the wall function. But this is the workaround we can propose for the moment. This is not ideal for a ship at full scale since it will increase the number of cells, we are fully aware of that and we will take good note for the future improvements. An alternative could be to isolate a patch at the bow and decrease roughness just in this area to limit this behavior...
    Best regards,
    Benoit
  • Halder
    Dear Mallol,
    @Mallol Thank you for kind support. I try to implement as suggested and check roughness.
    Please let me know how to access online fine/marine tutorial or could please allow me to access online learning material as well as tutorial.
    best regards,
    Paresh
