  2. OpenLabs
  3. Problems with openLabs
  • State Verified Answer
  • Replies 12
  • Subscribers 7
  • Views 15983
sriluta
sriluta over 3 years ago
Hey,
iam using OpenLabs because my inlet boundary conditions change with the time and the azimuth angle in the unsteady Simulation.  So OpenLabs works with SI Units. In the first time, I defined the pressure in bar ( since didn't know that OpenLabs works with SI Units and there the pressure is defined in pascal ). So with the following function implemented in OpenLabs  for the absolut total pressure I didn't got Problems:
 3.853 + (-0.9863)*cos(tCoord*1.966 + 2*PI*Time/timePeriod) + 0.08183*sin(tCoord*1.966+ 2*PI*Time/timePeriod) + (-0.2735)*cos(tCoord*3.932+ 2*PI*Time/timePeriod) + 0.6356*sin(tCoord*3.932+ 2*PI*Time/timePeriod) + 0.588*cos(tCoord*5.88 + 2*PI*Time/timePeriod) + (-0.1489)*sin(tCoord*5.88 + 2*PI*Time/timePeriod) + (-0.07768)*cos(tCoord*7.864 + 2*PI*Time/timePeriod) + (-0.2232)*sin(tCoord*7.864 + 2*PI*Time/timePeriod) + (-0.3242)*cos(tCoord*9.83 + 2*PI*Time/timePeriod) + 0.01536*sin(tCoord*9.83 + 2*PI*Time/timePeriod) + 0.1678*cos(tCoord*11.796+ 2*PI*Time/timePeriod) + 0.2214*sin(tCoord*11.796 + 2*PI*Time/timePeriod) + 0.1408*cos(tCoord*13.762 + 2*PI*Time/timePeriod) + (-0.0754)*sin(tCoord*13.762+ 2*PI*Time/timePeriod) + (-0.1216)*cos(tCoord*15.728 + 2*PI*Time/timePeriod) + (-0.1922)*sin(tCoord*15.728 + 2*PI*Time/timePeriod)
when I found out that OpenLabs works in SI units, I converted the sizes from bar to pascal and created the new following function:
390101.438+ (−99956.492)*cos(1.963*tCoord + 2*PI*Time/timePeriod)+ 9062.116*sin(1.963*tCoord + 2*PI*Time/timePeriod)+ (−26626.657)*cos(3.927*tCoord + 2*PI*Time/timePeriod)+63969.754*sin(3.927*tCoord + 2*PI*Time/timePeriod)+57284.906*cos(5.890*tCoord + 2*PI*Time/timePeriod) + (−15828.864)*sin(5.890*tCoord + 2*PI*Time/timePeriod) + (−8525.752)*cos(7.854*tCoord + 2*PI*Time/timePeriod) + (−21014.003)*sin(7.854*tCoord + 2*PI*Time/timePeriod) + (−30331.247)*cos(9.817*tCoord + 2*PI*Time/timePeriod)+2857.566*sin(9.817*tCoord + 2*PI*Time/timePeriod)+15956.411*cos(11.781*tCoord + 2*PI*Time/timePeriod)+19562.181*sin(11.781*tCoord + 2*PI*Time/timePeriod)+11641.815*cos(13.744*tCoord + 2*PI*Time/timePeriod) + (−6956.443)*sin(13.744*tCoord + 2*PI*Time/timePeriod) + (−10933.721)*cos(15.708*tCoord + 2*PI*Time/timePeriod) + (−14834.89)*sin(15.708*tCoord + 2*PI*Time/timePeriod).
If I click in OpenLabs at validate labs everything is fine, if I start the Simulation, the Simulation stops from beginning and say there is a problem with OpenLabs. I also defined the functions for the absolut Total Temperature and arctg( Vt/Vz) and there are no Problems but just with the pressure. Now I dont know what to do,
greetings Slight smile
  • Dianliang
    Dianliang over 3 years ago in reply to sriluta +2 verified
    You must provide the information of the boundary that will be customized. Otherwise, OpenLabs cannot know which boundary needs to be changed. The "Inlet" in FineOpen tutorial is the name of the boundary…
  • Dianliang
    Dianliang over 3 years ago in reply to sriluta +1
    Hi, OMNIS allows long expression. The problem is not due to the expression but something else. Next time, if you encounter the same issue, you can check the log file located in the folder _openlabs under…
  • Dianliang
    +1 Dianliang over 3 years ago in reply to sriluta
    The "Inlet" in FineOpen tutorial is the name of the boundary.
    • Vote Up +2 Vote Down
  • sriluta
    0 sriluta over 3 years ago in reply to Dianliang
    thx for your response, ah okay not only the boundary condition needs to be named, the boundary too. I want to modify the absolute total pressure and absolut total temperature at the inlet too, therefore i will use the name of the boundary conditions and the boundary inlet too, thx
