  2. Optimization
  3. Design3D Screening error: No mesh quality report file found...
  • Replies 8
  • Subscribers 5
  • Views 14227
Design3D Screening error: No mesh quality report file found or readable
JosephSmith
JosephSmith over 4 years ago
Hi everyone,
I have been trying to set up an optimization project in Design3D. It is for a centrifugal impeller with a blunt trailing edge (its a constant dmr blunt type). I had run an initial simulation in fine turbo and made a parametric model of the geometry in Autoblade. I used the geomturbo file from the Autogrid mesh as the target model for the Autoblade modelling.
My problem lies when I try running the Screening operation in Design3D. I get the following error seen in image 1 which appears after STEP 4 Mesh quality failed in the Task manager tab
Opening view computations info shows the following information:
The quality report file was missing from the above directory. It was only in the directory where I saved the Autogrid mesh files. So, I then pasted the MKS.quality report file in the above directory ( \_trk\_flow\_mesh). The same error still appeared even after adding the quality file to the directory. I suspect maybe its the ''not being readable'' error now.
I am not quite sure how to resolve this error and would appreciate any help. This error did not occur when I did the desgin3d tutorial 1
  • domen
    domen over 4 years ago +1
    Hello, the error may be a little misleading, but generally, this happens if the mesh generation fails thus the quality report is not created. Examples of the failure are: - "negative cells" in the…
  • domen
    domen over 4 years ago in reply to JosephSmith +1
    Just to be sure: this geometry comes from AutoBlade, right? The objective is to optimize the impeller while the volute is unchanged. If this is correct, I would double-check the parametrization in Autoblade…
  • domen
    OKOK. One trick is to let Autoblade extend the blade, you can do that in this menu: 0.05 should be enough. If Autogrid is not able to mesh, then my suggestion would be to check the stream surfaces…
  • JosephSmith
    JosephSmith over 4 years ago in reply to domen
    That resolved the error! Thanks for the help.
    I went past the screening process but was met with the following error
    It seems to be related to the quantities I selected in the outputs within Design3D. Some of the outputs I selected were new in Design3d and did not appear in my initial fineturbo simulation, such as P_min of Blade. I suspect that may be related to the error.
    Edit* I had left it on Compressible, instead of changing it to Incompressible in the Simulation Settings tab. It is now resolved
  • domen
    Make sure that in the output of Fine Turbo you have selected everything you need to compute those quantities ?(total pressure, temperature...).
    Some values are extracted from the mf file, but others are computed in CFView.
    Tip: always look for the job_* files (in Linux at least). They are where all programs log their actions. It's the best way to understand what went wrong.
  • JosephSmith
    Thanks domen. The mistake I made was selecting the fluid as Compressible, instead of incompressible, in the Simulation Setting within Design3d. Choosing incompressible resolved the errors.
