  2. Pointwise
  3. curve the mesh failed in PointWise for high order mesh
  • State Verified Answer
  • Subscribers 10
  • Views 10748
Studyhardhardhard
Studyhardhardhard over 2 years ago
Hello, everyone.
If I import a geometric model first, divide the grid on the basis of it, and then export it as a high-order curved grid, the grid is curved smoothly.
Now, if I have a grid of CGNS and the geometric model matched with this grid, I use pointwise software to open the model and geometric file and export it as a high-order curved grid.
The grid is not curved, and the exported result is a high-order straight grid. Why?
In this case, how can I generate curved high-order curved grids?
Thank you for everyone!
Best Regards
  • Claudio M Pita
    Claudio M Pita over 2 years ago +1
    Hello, If I understand correctly, you have a grid in CGNS format and the CAD data on a separate file in some format. You import the CAD file first and then the CGNS file with the grid. In this case,…
  • Claudio M Pita
    Claudio M Pita over 2 years ago in reply to Studyhardhardhard +1 verified
    Hello, Thank you very much for the additional information. Please note that this particular error is explained in the cited page of the User Manual. We also recommend a possible solution that may not…
  • Claudio M Pita
    0 Claudio M Pita over 2 years ago in reply to Claudio M Pita
    Hello again,
    On another thread, you asked the question below. As mentioned in that other thread, in order to keep things organized, I will reply to this question here.
    "By the way, after the high order curved mesh is generated, the Jacobian message is printed.But when I open the generated high order curved mesh with Gmsh and compute it using Gmsh’s mesh quality module, I find that the difference between Gmsh's minJ/maxJ and the Pointwise's Scaled Jacobian are not equal, please forgive my ignorance, I always thought Scaled Jacobian= minJ/maxJ, where did I misunderstand? How can I find out how the Jacobian, Scaled Jacobian, Normalized Jacobian is calculated after the high order curved mesh is generated and printed? I want to compare it with Gmsh's."
    Unfortunately, I am not familiar with Gmsh and how it computes Jacobians. As for Fidelity Pointwise, please refer to this paper for additional details on this topic: https://arc.aiaa.org/doi/10.2514/6.2016-3178.
    I hope this helps!
