  3. What is meant by Acid Trap?
  • Views 21727
girish
girish over 17 years ago
Hi, What is meant by Acid Trap? how can be avoided? Regards,Girish
  • steve
    steve over 17 years ago
    Acid Traps are generated when a gap from pad to trace is too small. They can be avoided by increasing the gap or moving the trace so that it exits the pad lower down the pad. Or you can use a gloss command to add a fillet from the pad exit.
  • girish
    Thanks Steve ,
    Could you please show any example & how to use Gloss command allegro designL 16 ver supports this?
    Girish Kumar
  • steve
    Girish
    Screenshot attached. I'm afraid you'll need Allegro Performance and above to do this with Gloss.
    HTH
    Steve
  • C Shiva
    C Shiva over 17 years ago
      Steve,
      What's the problem from these acid traps? Can it be changed the signal shape? I also faced same problem. Please help.
     Shiva.
  • pakistan
    pakistan over 17 years ago
    During cleaning of board chemicals may deposite there. thats why we have to route straight to minimize the probability.
