  3. LogoMaker - improved, and now multi-platform.
  • Replies 75
  • Subscribers 178
  • Views 47061
eDave
eDave over 16 years ago
Please, please, please follow the instructions fully when installing. They are at the top of the Skill file and also here:
Download and install the precompiled potrace release suitable for your platform:
  http://potrace.sourceforge.net/download
 set the POTRACE_PATH environment variable to the path to the executable
  eg. C:\utils\potrace
 Download and install the precompiled ImageMagick release suitable for your platform
 This may not be necessary if you use Linux as ImageMagick is often included in Linux installations:
  http://www.imagemagick.org/script/binary-releases.php
  eg. http://www.imagemagick.org/download/binaries/ImageMagick-6.5.3-Q16-windows.zip
 If the path to the ImageMagick convert.exe file is not in your system path then set the MAGICK_HOME
 environment variable to the path to the convert executable. (Run "convert -version" in a system shell to test).
  eg. C:\utils\ImageMagick\ImageMagick-6.5.1-3
 Install logoMaker_public.il into your skill folder.
 Add load("logoMaker_public.il") to the allegro.ilinit file in your pcbenv folder.
Happy logoing,
Dave
logoMaker_public.il
  • eDave
    See the attached image for an example.
  • oldmouldy
    oldmouldy over 16 years ago
    Hi Dave,
     You attached the "IL" file directly, it needs to be a zip to be downloadable from the forum - users get a "page not found" otherwise!
    Thanks!
  • eDave
    Oops. Here it is.
    Dave
    logoMaker_public.zip
  • C Shiva
    C Shiva over 16 years ago
     Dave, I have installed new logomaker version and unzipped and saved the imagemagick files in a folder. But instead of logomaker window a Plugin options window appears. Attached the screen shot. Please help.
    Shiva.
  • C Shiva
     Here is the logomaker file in which i have changed the path. Please verify whether it is correct.
