  3. Differential Pairs
  • Views 16141
Differential Pairs
melview1
melview1 over 15 years ago
Using OrCAD PCB Designer v16.3.S009
Can anyone help me on how to route a differential pair to be the same length and same separation during the whole route?  I'm sure there's some properties or modes I am missing that makes this easier than doing it manually.
Thanks.
--Mark
  • redwire
    redwire over 15 years ago
    Constraint manager: set up the differential pair definition.  Then assign the net pair to that definition.  It will route automatically to your width + spacing requirements.
  • melview1
    I don't have a lot of experience with constraing manager.  I've been in it, but I'm not quite sure where I define distances between 2 nets.  Could I bother you for a bit more detail?
    Thanks.
    --Mark
  • oldmouldy
    oldmouldy over 15 years ago
    You would need at least an Allegro PCB Design L license to get the necessary entries for differential pairs to appear in the Constraint Manager, the OrCAD PCB Designer has no native support for differential pairs.
    With Allegro PCB Design L, there is an additional Electrical domain in the Constraint Manager, this allows for the setting of the differential pair constraints.
  • melview1
    Well that sucks.  I guess I'll have to route them manually then.
    Thanks for the info.
     --Mark
