  3. how to add net manually in PCB editor ???
  • Views 19974
kabalee
kabalee over 13 years ago
Hi every one,
how to add net manually (i know it is not good but i need ) from one point to other point in PCB editor ,
please help any one !!!!!!!!!
  • steve
    steve over 13 years ago
    You need an Allegro XL license (16.3 or older) or Allegro PCB Designer + High Speed option to do this. Then use the Logic - Net Logic command.
    For anything less that the license make the change in the schematic and re-import the netlist or export a netlist from the PCB, edit and then re-import. There are many threads in this forum describing this process.
  • kabalee
     hi
    thanks for reply
    but in my design have only 5 components, logic --->net logic after that create new net name like (N12373) and select the pin .net N12373 has not  assign for this component (i have not schematic ) (how to add net even i followed your procedure)
  • steve
    You need to do Logic - Part Logic first and create the parts, then you can use Logic - Net Logic to add nets to the parts. It's much quicker to draw a schematic and do it properly (IMHO).
  • kabalee
    Hi steve, Thanks for your reply i know PCB design process should be follow, but i want to learn this thing also , i followed your procedure still i have some problem that is, i can assign net for C3 to C5 only i could not assign C5 to C4 what will i do ??? Rats assigned only assigned in one side only (i highlighted in yellow color) i need net like that .... please help for me
  • steve
    Not sure wothout seeing your design but Logic - Net Logic, then Create - Enter net name and then LMB (left mouse button) the pin(s) (they will hilight) and the net is added. To add parts to existing nets click Logic - Net Logic then click on the netname then click on the pins you want to add.
    Are there any error messages on the command line when you try to add the connections from C5 and C4 ? Are these parts added via the Part Logic function ?
