  3. Netlist creation problem ERROR(ORCAP-36071
  • Subscribers 166
  • Views 5311
Antscran
Antscran over 12 years ago
Hi all,
New here and fairly new to OrCAD, currently studying on an Embedded Systems degree and we have been supplied Orcad 16.5 under a student license.
I am reasonably comfortable with building a circuit and running various simulations using components from the pspice library.  And have got to a stage where I need to build a PCB, using the components that have come with OrCAD in the pspice library.
But I get a host of errors when I try to creat a netlist i.e. ERROR(ORCAP-36071): Illegal character "Forward Slash" etc.  I can see clearly what the error is by looking in the terminal window, and am able to navigate to the componets Foot print value.
I have the circuit open in OrCAD Capture CIS, click on the .dsn file and then go to the tools menu and select Creat Netlist, then I tick the box Open Board in OrCAD PCB Editor.
Quite confused at this stage and have the following questions related to this:
1)  Are there any library components supplied with Orcad that come with PCB Footprints that do not have this issue, or is this an error I am likely to get with certain libraries within OrCAD?
2) How can I identify what the valid footprint should be? (I know this is dependant on the component I use and relates to Question 3 I guess)
3) Is there a way I can preview all footprints so I can build a list up of known good ones for my circuits, then just copy paste from here to each component?
Thanks in-advance,
Ant
  • girish
    girish over 12 years ago
    1. Don’t use special characters in the footprint naming (* / space # ..etc) . Yes there are standard footprints are available in the installation directory if u have installed Orcad PCB editor (C:\Cadence\SPB_16.X\share\pcb\pcb_lib\symbols) U can make use of it . Make sure that you need to define this library path in the layout Tool (setup>user preference>paths>library>padpath & psm path) .
    2. To confirm which footprint to be mapped to the schematic part , Cross verify the package name (eg SOIC, TQFP ) & pin count ,pith between datasheet & footprint
    3. You can preview the footprint by opening it in a Orcad PCB editor or Allegro free viewer
    Best Regards,
    GK
  • Antscran
    GK,
    Thank you very much for the information very useful.
    Cheers,
    Ant
