  3. OK_UNASSIGNED_SHAPE
  • Views 13814
OK_UNASSIGNED_SHAPE
Cadence GDD
Cadence GDD over 12 years ago
I'm trying to find how to attach the OK_UNASSIGNED_SHAPE property to shape (see error report)
(    Shape Without Nets Report                         )
  Total shapes not on a net: 4
  Layer = TOP
Point on shape: (1065.00 5185.00)  Net: Dummy Net
Point on shape: (1065.00 2335.00)  Net: Dummy Net
Point on shape: (6725.00 1025.00)  Net: Dummy Net
Point on shape: (6725.00 5185.00)  Net: Dummy Net
    To suppress in report attach OK_UNASSIGNED_SHAPE property to shape.
  • oldmouldy
    oldmouldy over 12 years ago
    If you are really sure that you want to do this: General Edit Mode, Edit>Properties, Find Filter, All Off, Shapes only on, select the shape with a left-click and the Edit Properties window will pop-up, scroll through the left-hand list and find the OK_Unassigned_Shape entry, select it with a left-click and OK, right-click>Done in the canvas to confirm.
  • Cadence GDD
    Thank you for your help, I finally found the option!
