  3. Changing reference designators without re-placing compo...
  • Views 31955
Changing reference designators without re-placing components
aricbeaver
aricbeaver over 12 years ago
I have a board file and schematic that are linked. There are 5 different schematics and layouts (already manufacturered) each are independant of each other but are on the same board with v-grooves cut between them. I want to create a new schematic and board each of which are individual instead of together on one board. This would not be a problem but I would like to be able to change the reference designators on the schematic without re-placing the components on the board file after I import the netlist.
Is this possible?
  • Nayyierwajih
    Nayyierwajih over 12 years ago
    Go to file --.export palcement,generate a placement file ,open that file in excel replace old designators with new one and then import new placemant file after reloading the new netlist
    Hope it works
    Regards
    Nayyier
  • mcatramb91
    mcatramb91 over 12 years ago
    I am assuming that you have 5 schematics and layouts which are being combined during fabrication to
    form one PCB which is Assembled as one unit.  This means your reference designators are unique
    across all of the different sections (layouts) on the main (combined) PCB.  Now you are looking to
    update the layout and schematic so there is no gaps in the Reference Designator numbering when the
    boards are assembled individually.
    You have a couple of options:
     Option A
       Don't change the Reference Designators on the schematics but use Auto Rename in Allegro to rename
       the Reference Designators so there are no gaps in the numbering then back annotate the updated
       Reference Designators to the schematic.
       Here are the steps:
          1) Logic > Auto Rename RefDes > Rename, check Rename all components and click the MORE button.
          2) Clear the Top and Bottom Layer Identifier, Skip Character(s) then check Preserve current prefixes
          3) Click the CLOSE button on the Rename Ref Des Set Up form.
          4) Click the RENAME button on the Rename RefDes form.
             - This will rename the components so there are no gaps in the reference designators numbering.
             - Now you can back annotate the rename to the schematic and you are good to go.
     Option B
       If you prefer to make the changes on the schematic, just keep track of the Reference Designators
       FROM->TO and generate a text file "was-is_board1.txt" with column 1 being the OLD RefDes and column 2
       being the NEW RefDes as follows:
            U5     U1
            U6     U2
       This "was-is_board1.txt" text file can be used to rename the board prior to importing the single
       board netlist using the batch command REFTXT. Here is the command syntax that can be executed at
       a DOS Prompt as follows:
          reftext was-is_board1.txt combined_board.brd rename_board1.brd
             - This will rename the components based on the "was-is_board1.txt" text file
             - Once complete you can import the single board netlist.
    Hope this helps,
    Mike Catrambone
  • aricbeaver
    BOTH OF YOU ARE GOD. It's nice to have people to help.
  • Vipulc
    Vipulc over 2 years ago in reply to mcatramb91
     Syntax error in command...
    Command is:
    reftxt was-is_board1.txt combined_board.brd rename_board1.brd
    Not:
