  3. PCB Designer: How to unlock read-only keyboard shortcuts...
  • Subscribers 166
  • Views 14892
PCB Designer: How to unlock read-only keyboard shortcuts for setting script shortcuts with the alias / funckey command
garypchambers
garypchambers over 8 years ago
Having recently upgraded to 17.2 from 16.6 there now seems to be more read-only keyboard shortcuts. For example CTRL+Z (~Z), CTL+S (~S) etc... that were not readonly in 16.6
When trying to set these in 17.2 I get the response:   W- alias ~S is marked read-only, not changed.
This was not an issue with 16.6 and I would still like to use the same shortcuts I had setup previously. Is there a way to unlock this read only state in 17.7 for locked keyboard shortcuts?
  • FoCo
    FoCo over 8 years ago
    Anyone figure this out?  I have used these now read-only alias for about 14 years.  Now is not the time to remap my keyboard. Thanks.
  • B Bruekers
    B Bruekers over 8 years ago
    You can unset the protection with:
    alias_protect -n ~S
    alias_protect -n ~Z
    Somehow it does not work if you put these commands on the end of the ENV file, but putting it in the command prompt after start-up works fine (17.2.025).
    Edit:
    You can simply create a skill file which is loaded at startup. create a file, eg "unprotectAlias.il"
    Then add these lines in to the file:
    axlShellPost("alias_protect -n ~S")
    axlShellPost("alias_protect -n ~Z")
    Save the file and place it at a location where allegro.ilinit looks to load SKILL files at startup.
    Now when you start Allegro the ENV is loaded, then the SKILL files and when all is done the axlShellPost() command un-protects the 2 keys. The axlShell() does not work to un-protect during startup!
    Only remaining thing to do is to re-assign them to your wishes. Since you cannot do this before the protection is off you need to add 2 extra lines on the end of the same SKILL file, so it looks like this:
    axlShellPost("alias ~S save_test")
    axlShellPost("alias ~Z undo_test")
    Now when you start Allegro your ~S and ~Z keys are redefined to save_test and undo_test (as example!).
  • FoCo
    Thank you!! I use ~S/~Z for add connect and copy, so I was having a real hard time routing. Its hard to unlearn 15 years of hitting ~S/~Z a few hundred times a day. This fix works perfect! Thanks again.
