  3. Cadence Skill Syntax Highlighting in Notepad++
  • Subscribers 166
  • Views 25313
vramanax
vramanax over 10 years ago
I spent many hours trying to get back my original coding environment, then i realized I want to save everyone some serious headache
Long Story short
If you need syntax highlighting and use the function list option in Notepad++ Do the following
Install the latest build of notepad++
FunctionList.xml - place it on  %APPDATA%\AppData\Roaming\Notepad++\ - used for the functionlist window on notepad++
userDefineLang.xml - Place it on  %APPDATA%\AppData\Roaming\Notepad++\ - used to highlight the syntax
skill.api - Place it on %APPDATA%\AppData\Roaming\Notepad++\plugins\APIs\ - used for auto complete
myDark.xml place it on  %APPDATA%\AppData\Roaming\Notepad++\themes\ - mine you can use it to tune it to your taste
https://community.cadence.com/cfs-file/__key/communityserver-discussions-components-files/28/Notepad_2B002B00_.zip
Another recommendation is install and use Subversion/Tortoise SVN and commit as often as you can
Have Fun
Regards
Venkata
  • Ejlersen
    Ejlersen over 7 years ago in reply to Bijanbina +2
    Hi There's a guide for this on Cadence Online Support with a setup xml included. https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1O0V000006AhKSUA0&pageName=ArticleContent Best regards…
  • Bijanbina
    Bijanbina over 7 years ago
    Thanks, Very promising. BTW in newer version you need to check force background in Settings > Style Configurator
  • Ejlersen
    Hi
    Best regards
    Ole
    • Vote Up +2 Vote Down
  • singletree
    singletree over 5 years ago
    Other Options :Updated on 17-Dec-2020
    I started using Microsoft Visual Studio Code and it has been amazing in many levels.
    If you are serious developer then you would appreciate the built-in GIT support and the powerful interface similar to Sublime Text and Atom.
    Here are the highlights of my setup and the extension settings
    1. Every time I save a file the active file is copied to another directory on the local network location. (I do that to stage it)
    I use the extension Run on Save 0.2.0 and edit the user settings.json to modify your own location
    //start
    "emeraldwalk.runonsave": {
            "commands": [
                    "match": ".il$",
                    "cmd": "copy ${file} \"C:/yourdirctory/Development\""
                    "match": ".il$",
                    "cmd": "echo %time%"
    //end
    2. Use the Skill Syntax extension by Herbert Agosto v0.1.1 and you can update the settings in c:/users/username/.vscode/extensions/herbertagosto.skill-0.1.1 to customize to your needs
    3. use Bracket Select v2.0.2  extension select within braces
    4. Bracket Jumper 1.1.8 and Bracket Pair Colorizer is also useful
    5. This is the coolest CodeMap 1.16.0
    This one lists all the functions and partially will produce the outline of the code
    I use the following settings in the user settings.json you can play around to match your requirement
    //start
    "codemap.il": [
                "pattern": "(?=if\\().[^)]+.?",
                "clear": "",
                "prefix": "",
                "icon": "level3"
    // you can add the similar rules for all the loop functions, don't go overboard
                "pattern": "(?<=procedure\\( ).[^)]+.?|(?<=procedure ).[^)]+.?",
                "clear": "",
                "prefix": "",
                "icon": "class"
                "pattern": "(?=defun).[^)]+.",
                "clear": "",
                "prefix": "",
                "icon": "function"
                "pattern": "(?<=defvar).[^)]+",
                "clear": "",
                "prefix": "var: ",
                "icon": "property"
    //end
    6. I use GitLens to quickly see the history of my edits
    7. Use Atom One Dark Theme
    Have fun
