  3. Hierarchy tree in SKILL from normal schematic, config based...
  • Views 22153
Hierarchy tree in SKILL from normal schematic, config based schematic and layout
skillprogramme
skillprogramme over 13 years ago
Hi!
I am working on some code to return the hierarchy below a given cell, irregardless of the cell being a layout or schematic and irregardless of the eventual schematic being normal or config based. In the solution provided by Cadence (linked at end of post), this is done through GUI forms. I would however like to do everything in SKILL, without any open window sessions (other than CIW).
In the solution it is checked if the schematic has a config view by calling deGetConfigId with window_id as argument. As I would like to do everything from SKILL, I need some other function to do this. Is it any function that can return if a schematic has a related config?
As well, the solution states that normal schematic (and thus layout) trees (no related config, that is) can be printed in non-GUI mode by invoking CCSschTree directly from CIW. It does not say anything about it being possible to call the config based equivalent CCShdbSchTree from CIW. Would it be possible to do this and if not, why?
Cheers,
Max
Related Cadence solution:
https://support.cadence.com/apex/homePage
    Hi Max,
    You can blame the author of the solution (it was me...) for not including that example in the text - that's mainly because the solution originally dates from before I added config support back in 2006). It does however mention the function in the comments at the top of the code - as a perfectly acceptable function to call from SKILL. So yes, you can do that.
    You call it with the lib/cell/view of the config view. If you've opened a config view (along with the configured schematic), then you can get the "hdb" handle using deGetConfigId as you've seen. You can then use:
    hdb=deGetConfigId(hiGetCurrentWindow())
    confLib=hdbGetLibName(hdb)
    confCell=hdbGetCellName(hdb)
    confView=hdbGetViewName(hdb)
    which will get you the lib/cell/view of the config view associated with that configured schematic.
    I suspect that you're asking for a way to do this without opening the schematic. Actually what you're opening graphically is the configured schematic - you tell it the config view, and from that it knows the top lib/cell/view and shows you the schematic.
    However, if  you just open a schematic directly (either graphically or with dbOpenCellViewByType()), you cannot know which config is "related". The schematic doesn't have info about related configs - because there could be 10 different config views  for the same top schematic. It's the other way around - the config says which schematic it is configuring.
    So you can call this function with the lib/cell/view of a config that you want to use.
    Note that the version of the code in the solution doesn't support layout views - only schematic. I have a newer version (version 1.9; the version on the support site is 1.5) which supports layout views as well. I'll get it uploaded (once I've sorted out a permission problem).
    Kind Regards,
  • skillprogramme
    I was searching for a function that could take a schematic database id (returned by dbOpenCellViewByType() for instance) and tell me the related config view if it existed, assuming a one-to-one correspondence. But as you wrote and I now understand, it is the other way around, with possibly many config views relating to a specific schematic.
    I will consider if I actually need the config support or not.
    Relating to the same topic, my code ends up calling dbOpenCellViewByType for each cell traversed in the hierarchy with some smart chekcing to avoid calling it for already checked instances. By closing a view with dbClose after returning its instances I save memory, however, consequtive calls to the same code does not get the advantage of having the cells in the virtual memory. What would be the best approach in your opinion here? Will consecutive calls to dbOpenCellViewByType with the same arguments leak virtual memory and cause swapping activity over time?
    Max
  • skillUser
    skillUser over 13 years ago
    Hi Max,
    A quick answer to your question "Will consecutive calls to dbOpenCellViewByType with the same arguments leak virtual memory and cause swapping activity over time?" - no, when the same cellview is opened multiple times this is handled efficiently in Virtuoso by increasing a counter for the number of references pointing to the celliew database id.  Each time a reference is closed the counter is reduced by one; when the counter hits 0 the virtual memory is freed. Another efficiency that you may not be aware of is the instHeaders in a cellview virtual memory representation - each instHeader corresponds to a cell that is used in that cellview, whether it is instantiated once or hundreds of times.  Subsequently if you just need to process cells rather than unique instances, you can iterate through the instHeaders (e.g. cv~>instHeaders versus cv~>instances).
    I hope this helps.
    Lawrence.
    I've now updated the version on the support site.
    Kind Regards,
  • skillprogramme
    Excellent Andrew, I'll have a look at it!
    Thanks for the input Lawrence, I think that will speed things up a little!
    Max
