  3. SKILL code to print all the labels in a layout view to a...
  • Views 21105
SKILL code to print all the labels in a layout view to a file
vvangap
vvangap over 13 years ago
        I am new to skill, I would like to search for all the labels in a layout and print them in a file. I dont want to traverse through the hierarchy. Is there a skill function to do that or if not can you please provide a small code snippet to do the same.
 Here is a small code snippet, I am trying to run
procedure(printLabels()
   cv= getGetWindowCellView()
    myPort = outfile("/home/vvangap/tmp/printLabels.txt")
   ;;let((cv shape)
      /****Operating on the desired property****/
      foreach(shape cv~>shapes
         if(shape~>objType == "label" then
            fprintf(myPort "\n Label:  %L" shape)
         )/****end of if****/
      )/****end of foreach****/
  ;;)/****end of let****/
)/****end of procedure****/
The above code prints the database numbers in the CIW window, but I need the labels itself to be printed in the printLabels.txt file.
Vikram
    Vikram,
    Just use shape~>theLabel in your fprintf - this is the text of the label itself.
  • vvangap
    Thanks Andrew it works,
    Vikram
  • Mallikarjun032
    Mallikarjun032 over 7 years ago in reply to Andrew Beckett
    In the above script, is there a way to find the coordinate location of a label?
    Mallikarjun
    Andrew Beckett over 7 years ago in reply to Mallikarjun032
    Hi Mallikarjun,
    It's not my code, but you could use shape~>xy to find the coordinate (origin) of the label.
