  3. how to select and deselect a layer using only one bind key...
  • Replies 13
  • Views 28857
how to select and deselect a layer using only one bind key?
IC Layout
IC Layout over 17 years ago
 Hello! Everybody, GoodEvening to all,
Please, can anybody help me in giving the solution for this question.
I am using cadence IC514 version.
I would like to select a layer using one bind key also it should deselect the same layer if I press the same bind key.
Thanks in advance...
                             waiting for Ur replys.........
                                            Prabhakar-The VLE
  • skillUser
    skillUser over 17 years ago +1
    Hi Prabhakar, I will guess that you are talking about selecting shapes on a specific layer-purpose pair since you also mentioned deselection. There are probably a few different approaches that you could…
  • 151515
    151515 over 14 years ago
    Austin,
    Can you please give me reference material/links to learn all these skill Layout commands.
    In IC61, run cdnshelp and then search for the function name in question. In IC5141 run "cdsdoc". Alternatively use the Help menus inside virtuoso to bring up the help system and search there.
     Oh, and the Forum Guidelines suggest that you don't add onto an old thread.
