  3. Implementing flow control in rodCreatePath function
  • Replies 12
  • Subscribers 153
  • Views 24313
infy
infy over 17 years ago
Can we Implement flow control structures like if,while in rodCreatepath function to control the number of offset subpaths.
Roy
    Andrew Beckett over 17 years ago
    Roy,
    You didn't give the stack trace output, but it's fairly obvious from looking at the code that the function:
    procedure(CCSmetBusCB(cv width  layer points  "dfll")
    is expecting the 3rd argument to a layer purpose pair. The code as you sent it does not give an error - so I assume this was because you were calling this function:
            CCSmetBusCB(
              win->cellView
              form->width->value
    ;          form->number->value
              CCSgetLPPfromLayerCyclic(form->layer->value)
              points
    with the number argument not commented?
    Clearly you would have to pass number into the CCSmetBusCB function, and update the argument list appropriately. I also think that it makes more sense for the number field to be an integer rather than float field (since you can't draw 2.5 bus wires!).
    Overall I've changed the code below:
    procedure(CCSmetBus()
      let( (form)
     if(boundp('CCSmetBusForm) && CCSmetBusForm then
          form = CCSmetBusForm
        else
          form = CCScreateMetBusForm()
        ); if
        when(hiIsForm(form)
          enterPath(
            ?prompts        list("Enter points for Metal Bus path")
            ?form           form
            ?points         nil
            ?doneProc       "CCSmetBusDoneProc"
            ?addPointProc   "CCSmetBusPoints"
            ?delPointProc   "CCSmetBusPoints"
            ?pathWidth      form->width->value
           ;?acceptString  form->number->value
            ?alwaysMap      t
            ?cmdName        "CCSmetBus"
          ); enterPath
        ); when the form exists
      ); let
    ); procedure CCSmetBus
    procedure(CCScreateMetBusForm()
      let( (width number layer snap snapModes form cv techId)
        if(cv = geGetEditCellView(hiGetCurrentWindow()) then
          if(techId = techGetTechFile(cv) then
     width = hiCreateFloatField(
              ?name 'width
              ?prompt "Width"
              ?value 1.0
              ?range list(0.3 2.0)
              ?callback "CCSchangeMetBusWidth()"
              ); hiCreateFloatField
    ;; ADB changed to integer field
     number = hiCreateIntField(
                ?name 'number
                ?prompt "Number"
                ?value 1
                ?range list(1 100)
    ;; ADB - I don't think this is really needed, as it doesn't affect
    ;; anything. It's not like the width, where you want the ghost image of
    ;; the path to change.
                ?callback "CCSchangeMetBusNumber()"
    snapModes = list("orthogonal" "L90XFirst" "L90YFirst")
            snap = hiCreateCyclicField(
              ?name 'snap
              ?choices      snapModes
              ?prompt       "Snap mode"
              ?value        car(member(envGetVal("layout" "snapMode")
                              snapModes)) || "orthogonal"
              ?callback     "CCSchangeMetBusSnap()"
            ); hiCreateCyclicField
    layer = hiCreateLayerCyclicField(
              techId
              "Layer"
              leGetValidLayerList(techId) || list(leGetEntryLayer(techId))
              'layer
            ); hiCreateLayerCyclicField
     form = hiCreateAppForm(
              ?name 'CCSmetBusForm
              ?formTitle "Metal Bus"
              ?formType     'options
              ?buttonLayout 'HideCancelDef
              ?fields list( list(width 0:0 100:30 50)
                list(snap 120:0 100:30 70)
                list(number 0:30 200:30 50)
               list(layer 0:90 200:30 50))
            ); hiCreateAppForm
     leSetFormSnapMode(form->snap->value)
            CCSshieldMetalForm = form
          else
            error("Could not obtain technology information")
          ); if the technology information can be obtained
        else
          error("Shield metal functions require a cellview to be current")
        ); if a current cellview exists
      ); let
    ); procedure CCScreateMetBusForm
    procedure(CCSchangeMetBusWidth()
      let( (origWidth)
        when(boundp('CCSmetBusForm) && CCSmetBusForm
          origWidth = CCSmetBusForm->width->value
          CCSmetBusForm->width->value = origWidth
          unless(CCSmetBusForm->currentWidth == CCSmetBusForm->width->value
            CCSmetBusForm->currentWidth = CCSmetBusForm->width->value
          ); unless
          changeEnterFun(
            'enterPath
            ?pathWidth      CCSmetBusForm->width->value
            ;?acceptString     CCSmetBusForm->number->value
            ?points         CCSmetBusForm->points
            ?form           CCSmetBusForm
          ); changeEnterFun
      ); let
    ); procedure CCSchangeMetBusWidth
    procedure(CCSchangeMetBusNumber()
      let( (defaultNumber)
          defaultNumber= CCSmetBusForm->number->value
          CCSmetBusForm->number->value = defaultNumber
          unless(CCSmetBusForm->currentNumber == CCSmetBusForm->number->value
            CCSmetBusForm->currentNumber = CCSmetBusForm->number->value
          ); unless
          changeEnterFun(
            'enterPath
            ?form           CCSmetBusForm
          ); changeEnterFun
      ); let
    ); procedure CCSchangeMetBusNumber
    procedure(CCSchangeMetBusSnap()
        CCSmetBusForm->origSnap =
          leSetFormSnapMode(CCSmetBusForm->snap->value)
    ); procedure CCSchangeMetBusSnap
    procedure(CCSmetBusPoints(win points "wl")
      when(windowp(win)
        ;; keep track of the points for when the enterFunction is changed
        CCSmetBusForm->points = points
    ); procedure CCSmetBusPoints
    procedure(CCSmetBusDoneProc(win done points "wgl")
      let( ( form )
          if(done then
            ;; reset the currentWidth variable stored on the form
            ;; and reset the points list stored on the form
            form->currentWidth = nil
            form->currentNumber = nil
            form->points = nil
            CCSmetBusCB(
              win->cellView
              form->width->value
    ;; ADB - removed comment so that number is now passed
              form->number->value
              points
          else
            ;; put back the most recent previous snap mode
            when(CCSmetBusForm->origSnap
              leSetFormSnapMode(CCSmetBusForm->origSnap)
            ); when
          ); if done
        ); when form exists
      ); let
    ); procedure CCSmetBusDoneProc
    ;; ADB - Added number as a formal argument (x in type template)
    procedure(CCSmetBusCB(cv width number layer points  "dfxll")
    ;; ADB - some local variables here wouldn't go amiss! Try running through
    ;; SKILL Lint to see what it says
    if( (width >=  techGetSpacingRule(techGetTechFile(cv) "minWidth" layer)) then
    layerWidth = width
    );if
    layerSpace = techGetSpacingRule(techGetTechFile(cv) "minSpacing" layer)
    let((a b n)
    b = list()
    a = list()
    ;; ADB - removed hard coding of number
    ; number = 10
    n = number
    for(i 0 n-2
    a= list(
                                ?layer      layer
                                ?justification "left"
                                ?width layerWidth
                                ?sep  ( layerSpace * (i+1)) + ( layerWidth * i)
                                ?choppable  t
    b = cons(a b)
    );for
    b = reverse(b)
    rodCreatePath(
          ?cvId             cv
          ?layer            layer
          ?width            layerWidth
          ?pts              points
          ?justification "center"
          ?choppable  t
          ?offsetSubPath    b
       ); rodCreatePath
      );let
    ); procedure CCSmetBusCB
    procedure(CCSgetLPPfromLayerCyclic(layCyc "l")
      parseString(
        buildString(
          parseString(cadddr(layCyc) "()")
    ); procedure CCSgetLPPfromLayerCyclic
  • Infy1
    Infy1 over 17 years ago
     hi,
    Thanks Andrew.It's working !!!!
    Roy
