  3. How to calculate area for a given schematic
  • Replies 13
  • Views 27069
IC Layout
IC Layout over 17 years ago
 Hello! Every body, I am using cadence IC514 version and a 90nm PDK kit called "gpdk090".
My intention is to calculate area for a given schematic.
I wrote a procedure called "area()" which will calculate area in the current level (means for transistors, capacitors and resistors only).
Now I need to call this procedure for every instance which is not a transistor,cap or a resistor.
I wrote something like this........................
foreach( inst geGetEditCellView()~>instances
    when( inst~>purpose == "cell"
        if( inst~>libName == "gpdk090" then
            area()
        else
            label:
            cv1=dbOpenCellViewByType(inst~>libName inst~>cellName "schematic")
            foreach( inst1 cv1~>instances
                when( inst1~>purpose == "cell"
                    if( inst1~>libName == "gpdk090" then
                        area()
                    else
                        goto label
Can some body guide me in this way...
                Thanks in Advance...
        Prabhakar. K
  • IC Layout
     Suppose If I have four 4:1 mux's and to resitors and few transistors/caps & each mux is having again two 2:1 mux's inside ..
    Now along with the total area I would like to have the area of each 4:1 Mux separately ...
    I am sending my code here..please notice the comment where I am getting the problem
    totalArea = 0u
      procedure( area(inst)
                   if( inst~>cellName == "pmos2v"  then
                       w1 = cdfParseFloatString(dbGetq(inst "w"))
                       l1 = cdfParseFloatString(dbGetq(inst "l"))
                       m1 = cdfParseFloatString(dbGetq(inst "m"))
                       f1 = cdfParseFloatString(dbGetq(inst "fingers"))
                           wp = w1 + 1.4u
                           lp = f1*l1 + (f1-1)*0.36u + 2u
                                   AREA = m1*wp*lp
                   else
                   if(inst~>cellName == "nmos2v"  then
                           wn = w1 + 0.6u
                           ln = f1*l1 + (f1-1)*0.36u + 1.2u
                                   AREA = m1*wn*ln
                  else
                  if((inst~>cellName == "mimcap" ) then
                       c1 = cdfParseFloatString(dbGetq(inst "c"))
                                   areac = m1 * c1
                                   AREA = areac/AA
                   else
                   if(inst~>cellName == "resnsppoly"  then
                       w1 = cdfParseFloatString(dbGetq(inst "segW"))
                       l1 = cdfParseFloatString(dbGetq(inst "segL"))
                       m1 = dbGetq(inst "segments")
                           wr = m1*w1 + (m1-1)*0.6u + 0.56u
                           lr = l1 + 1.12u
                                   AREA = wr * lr
    AREA
     );proc1
      procedure( PKsumArea(@optional (cv geGetEditCellView()))
           foreach(inst cv~>instances
                   if(inst~>libName == "gpdk090" then
                      totalArea = totalArea + area(inst)
          else
                   when(inst~>purpose == "cell"
                   master = dbOpenCellViewByType(inst~>libName inst~>cellName "schematic")
                   ;;;;;;;;;;;;;;;;;;;;;for this particular 'master' --if it refers to toplevel schemaic --I need to get this area ;;;;;;;;;;;;;;;;;;;;;;;;;;;;
                   when(master
                   println(master~>cellName)
                   PKsumArea(master)
    totalArea
    PKsumArea()
    println(totalArea)
    If still unclear I will send some more trials where I faild ........
    thanks & regards
                              Prabhakar. K
    Andrew Beckett over 17 years ago
    OK. I've tidied up the code, removed the global variables (made them local, except for AA which I didn't know what it was), changed the nested if-then-else in the area function to be a case(), coped with unrecognized devices, and added something to print out the area of the top level blocks as it goes along.
    ; globals used in this code that I can't account for:
    ; AA
    procedure( PKinstArea(inst)
      let((w1 l1 m1 f1 wp lp wr lr wn ln c1 areac AREA)
        case(inst~>cellName
          ("pmos2v"
            w1 = cdfParseFloatString(inst~>w)
            l1 = cdfParseFloatString(inst~>l)
            m1 = cdfParseFloatString(inst~>m)
            f1 = cdfParseFloatString(inst~>fingers)
    	wp = w1 + 1.4u
    	AREA = m1*wp*lp
          ("nmos2v"
    	wn = w1 + 0.6u
    	AREA = m1*wn*ln
          ("mimcap"
    	c1 = cdfParseFloatString(inst~>c)
    	areac = m1 * c1
    	AREA = areac/AA
          ("resnsppoly"
    	w1 = cdfParseFloatString(inst~>segW)
    	l1 = cdfParseFloatString(inst~>segL)
    	m1 = inst~>segments
    	lr = l1 + 1.12u
    	AREA = wr * lr
          (t
    	warn("Unrecognized device %L\n" inst~>cellName)
    	AREA = 0.0
        ) ; case
        AREA
      ) ; let
    ) ; procedure PKinstArea
    procedure( PKsumArea(@optional (cv geGetEditCellView()) (topLevel t))
      let((master instArea (area 0.0))
    	area=area+PKinstArea(inst)
          else
    	    "schematic")
    	  when(master
    	    instArea=PKsumArea(master nil)
    	    when(topLevel
    	      printf("Instance %s of %s has area %g\n" inst~>name
    		inst~>cellName instArea)
    	    ) ; when topLevel
    	    area=area+instArea
    	  ) ; when master
    	) ; when purpose is cell
          ) ; if
        ) ; foreach
        area
    ) ; procedure PKsumArea
    totalArea=PKsumArea()
    printf("Total area is %g\n" totalArea)
  • IC Layout
     Thanks a lot.....Sir, This is what I suppose to have...
    Really, I inspired with your valuable suggestions......
                                 Prabhakar. K - Layout Design Engineer
