  3. Need the X:Y co-ordinates of the point
  • Replies 12
  • Views 11111
Chin Cypress
Chin Cypress over 17 years ago
Hello all
          I need the x:y co-ordinates of the point where i clicked in the layout editor window.
Requirement : need to get the points and print in to the file.
 Please suggest the command to be used ASAP
Rgds
Chin
    Andrew Beckett over 17 years ago
    Sorry - I didn't read the manual for leZoomToPoint - I was just taking your code as a starting point; I shouldn't have assumed it was correct.
    Now that you've explained your requirement - which would have been the best thing to do in the first place, as it is now obvious what you're trying to do.
    I have some SKILL code which does what you want - or similar - albeit in a rather different way. I'll post it later when I've got a proper connection.
    Here's the code. Define a bindkey which calls abCopyWinView() . When you press the bindkey it will prompt you to pick two windows (source and destination) - or just destination if you have infix on - and will copy the zoom position from one window to the other.
    (procedure (abCopyWinViewCB win done points)
      (let (bbox)
           (setq win (hiGetCurrentWindow))
           (when (and done (windowp win) (windowp abCopyWinViewFrom))
                 (setq bbox (hiGetViewBBox abCopyWinViewFrom))
                 (hiZoomIn win bbox))))
    *             (abCopyWinView @optional (win nil))              *
    *     Procedure to copy a view from one window to another      *
    (procedure (abCopyWinView @optional (win nil))
      (unless win (setq win (hiGetCurrentWindow)))
      (setq abCopyWinViewFrom win)
      (hiSetCurrentWindow win)
      (when (windowp win)
            (enterMultiRep ?prompts '("Point to the source window" "Point to the destination window")
                           ?points '((0 0))
                           ?doneProc "abCopyWinViewCB"
                           ?dontDraw t
      t)
