  3. XML in SKILL
  • Replies 11
  • Subscribers 150
  • Views 24993
XML in SKILL
ToMWUT
ToMWUT over 17 years ago
Hello All,
In my SKILL++ application I have to store some configuration data on my local hard drive. My question now is how to do this? In standard programming languages I’d use an XML file. Is it possible to use XML in SKILL or maybe I would have to write all parsing of the XML by my own? If the last possibility is valid than only simple text file (values separated by ; for example) is left as a solution, am I right?
ToM
  • mantang
    mantang over 8 years ago in reply to Andrew Beckett
    Thank you for your info. I guess IT does not install libxslt, so I cannot test it.
    ls /usr/bin/xlstproc
    ls: cannot access /usr/bin/xlstproc: No such file or directory
    ManChak
