  3. How to replace Vias in Virtuoso6.1.3 version.
  • Subscribers 150
  • Views 14170
VEERA PRAMOD
VEERA PRAMOD over 16 years ago
Hi all..
I used the command "leReplaceAnyInstMaster(car(geGetSelSet()) nil "Via to change" nil)" to replace a VM1_M2 with other.But at the CIW i am getting "nil" and that VM1_M2 is not chaning to other.If any one know how to change a via from one to other please give reply.
Thank you.
Veera.K Pramod
  • skillUser
    skillUser over 16 years ago
    Hi Veera,
    In IC613 vias are no longer instances but OA objects, so they have a different interface for creation.  Try the dbCreateVia() function in combination with something like dbFindViaHeaderByName() (or techFindViaDefByName(), or techFindViaSpec()) to obtain the via definition.  I'm not sure about changing one via placement to another, you may need to store the parameters from the original placement for use with the second?
    I hope that this answers your question.
    Best regards,
    Lawrence.
  • cadence screen
    cadence screen over 13 years ago
    I want to place vias based on area selection. I m using Open access version. Can you please explain indetail of dbCreateVia() option, with example.
    Surya
    Please read the Forum Guidelines (this suggests that posting on a 3 year old thread is not a good idea).
    There's an example of using dbCreateVia in the documentation. Did you look at that? Type "cdnshelp" at the command line, or use the Help-> menus in Virtuoso. It's searchable, so you can search for dbCreateVia
