  3. Help on skill code for unselecting/selcting objects like...
  • Replies 23
  • Views 18792
Help on skill code for unselecting/selcting objects like path/wire, rectangle/polygon etc.
zeroskills
zeroskills over 16 years ago
Hi All,
First of all, i have no talent doing skill code, i have very very basic knowledge of it. here's my request, and i think it's possible because if did some reseach on it, i just don't know how to do it.
Problem:
For example, i have a wire/path and a rectangle/polygon overlapping each other, i would like to select "only" the wire/path and not the rectangle/polygon. it would be nice if there's a skill code that can turn off or on wire/path or rectangle/polygon selection like the instance button on the LSW window.
So basically i would like to have something like the intance turning on or off selection, like this...
--->leSetObjectSelectable("inst" t) instance is selectable or
--->leSetObjectSelectable("inst" nil) instance is unselectable
But i would like something like this for other objects, like wire/path, rectabgle/polygon etc. not necessarily a button but i would like it to toggle, like "shift+w" to turn it on or off using if statements.
Thanks in advance, I hope someone could help me.
  • zeroskills
    Yes, i loaded 3 of them:
    load("/user/me/abLeMultiSelectionFilter.ils")
    this from your new code (no window pop up)
    load("/user/me/abShapeSelectionFilter.ils")
    load("/user/me/abToggleForm.il")
    ;;BINDKEYS
    hiSetBindKey("Layout" "Ctrl<Key>7" "abShapeSelectionSetFilter(?togglePath t)")
    hiSetBindKey("Layout" "Ctrl<Key>8" "abShapeSelectionSetFilter(?togglePolygon t)")
    hiSetBindKey("Layout" "Ctrl<Key>9" "abShapeSelectionSetFilter(?toggleText t)")
    and it doesn't work. i don't know why, it was working  yesterday until i crashed today. i've been doing boot and reboot and still the same.
    it's strange.
    i even tried loading your old code with the pop up window and it doesn't work. i get errors.
    Well done, you've found the deliberate mistake in the code ;-) . After adding the ability to toggle or set each of the path, polygon and text modes, I forgot to ensure that the filter was actually registered. Essentially as it stood, it only works if you have first invoked the form, turned one of the checkboxes off, and then hit OK or apply. After that, the toggle functions would work (unless you used the form to turn back on all selections).
    Anyway, I've updated the code to take care of the filter registration whether you use the form or the direct call to abShapeSelectionSetFilter(). Here's the new code:
    /* abShapeSelectionFilter.ils
    Author     A.D.Beckett
    Language   SKILL
    Date       Dec 02, 2008
    Modified   Sep 17, 2009
    By         A.D.Beckett
    Main entry point:
    abShapeSelectionFilter()
    Brings up form, asking you to choose which type of shape objects
    are selectable.
    Written in C syntax to allow ease of modification by those scared
    of LISP ;->
    Requires abToggleForm.il and abLeMultiSelectionFilter.ils to
    be loaded first.
    Can also use:
    ; specify t or nil for whichever options you want to set or
    ; unset those options
    abShapeSelectionSetFilter(?setText t ?setPolygon t ?setPath nil)
    ; specify whichever keywords you want to toggle them
    abShapeSelectionSetFilter(?toggleText t ?togglePolygon t ?togglePath t)
    ; e.g. just toggling paths
    SCCS Info: @(#) abShapeSelectionFilter.ils 09/17/09.22:21:18 1.3
    importSkillVar(abShapeSelectionFilterForm)
    let(((pathsOK t) (shapesOK t) (textOK t) registered)
        *                        (displayForm)                         *
        *     Local function, exported as abShapeSelectionFilter()     *
        *   which creates form if not already created, and displays    *
        *                             it.                              *
        defun(displayForm ()
    	unless(boundp('abShapeSelectionFilterForm)
    	    abCreateToggleForm(
    		?name 'abShapeSelectionFilterForm
    		?prompt "Check selectable objects:"
    		?textList '("Paths/Path Segments" "Polygons/Rects" "Text")
    		?callback 'abShapeSelectionFilterCB
    		?formTitle "Filter objects"
    		?buttonLayout 'OKCancelApply
    		?toggleHeight 80
    	    ) ; abCreateToggleForm
    	) ; unless
    	abToggleFormSetSelected(abShapeSelectionFilterForm
    	    list(
    		list("Paths/Path Segments" pathsOK)
    		list("Polygons/Rects" shapesOK)
    		list("Text" textOK)
    	    ) ; list
    	) ; abToggleFormSetSelected
    	hiDisplayForm(abShapeSelectionFilterForm)
        ) ; defun
        *                      (regOrUnregFilter)                      *
        * Local function to take care of registering or unregistering  *
        *                          the filter                          *
        defun(regOrUnregFilter ()
    	if(!textOK || !shapesOK || !pathsOK then
    	    unless(registered
    		registered=t
    		abLeRegUserObjectSelectionFilter(
    		    "abShapeSelectionFilterFilter"
    	else
    	    when(registered
    		abLeUnregUserObjectSelectionFilter(
    	    registered=nil
    	) ; if
        ) ; defun regOrUnRegFilter ()
        *                       (formCallback form)                       *
        *   Local function, exported as abShapeSelectionFilterCB, which   *
        * takes choices from form, and updates lexically scoped variables *
        *    to remember settings - so that the filter() function can     *
        *                         reference them.                         *
        defun(formCallback (form)
    	let((choices)
    	    choices=abToggleFormGetSelected(form)
    	    pathsOK=shapesOK=textOK=nil
    	    foreach(choice choices
    		case(choice
    		    ("Paths/Path Segments" pathsOK=t)
    		    ("Polygons/Rects" shapesOK=t)
    		    ("Text" textOK=t)
    	    ; Ensure filter is registered or unregistered as needed
    	    regOrUnregFilter()
    	) ; let
        ) ; defun formCallback
        *  (setOrToggle @key (setPath 'unbound) (setPolygon 'unbound)  *
        *   (setText 'unbound) togglePath togglePolygon toggleText)    *
        *     A function to allow non-form setting or toggling of      *
        *                various shape filter choices.                 *
        defun(setOrToggle (@key (setPath 'unbound) (setPolygon 'unbound)
    	when(togglePath pathsOK=!pathsOK)
    	when(togglePolygon shapesOK=!shapesOK)
    	when(toggleText textOK=!textOK)
    	when(neq(setPath 'unbound) pathsOK=setPath)
    	when(neq(setPolygon 'unbound) shapesOK=setPolygon)
    	when(neq(setText 'unbound) textOK=setText)
    	regOrUnregFilter()
    	; Refresh the form if needed
    	when(boundp('abShapeSelectionFilterForm) &&
    	    hiIsFormDisplayed(abShapeSelectionFilterForm)
    	    displayForm()
    	t
        ) ; defun setOrToggle
        *                         (filter obj)                         *
        *       The actual selection filter. This is exported to       *
        *      abShapeSelectionFilterFilter. Compares the objType      *
        *     of the object with certain values, and then returns      *
        *    the value of the flag where the user has chosen which     *
        *                       are selectable.                        *
        defun(filter (obj)
    	case(obj~>objType
    	    (("path" "pathSeg") pathsOK)
    	    (("rect" "polygon") shapesOK)
    	    (("label" "textDisplay") textOK)
    	    (t t)
    	) ; case
        ) ; defun filter
        ; Export all the functions
        abShapeSelectionFilter=displayForm
        abShapeSelectionFilterFilter=filter
        abShapeSelectionFilterCB=formCallback
        abShapeSelectionSetFilter=setOrToggle
    Best Regards,
  • zeroskills
    Thanks Andrew! Now it's working again.
    I had the same the idea, since i've been playing with the form window before so i think that triggered the "no form" and direct to toggle. but the problem was, even with the form window, i can't make it work, so i can't actually prove it.
    Thanks again!
