  3. StrmOut from Virtual Memory
  • Replies 13
  • Views 23599
Yaosan
Yaosan over 16 years ago
I would like to make some modifications to my cellview in scratch view mode and stream that out directly from virtual memory. Is there a way for me to do it using SKILL i.e. without using the GUI (File > Export > Stream...)?
Thanks in advance!
  • Yaosan
    You're right, thanks for the reply. Now I manage to stream out my design from the virtual memory, but once the gds is done, a dialog box will pop up showing how many errors and warnings are found and prompt user if they want to look at the log file. Is there a way to prevent this dialog box from showing up?
    The reason for this is that I need to do some post processing once the gds is done but my script cannot continue until the user interacts with this dialog box by clicking "Yes" or "No".
  • Yaosan
    Sorry for bumping this post but I would like to know if there's any way to turn off the dialog box that pops up after the streamout is done, which stops the flow of my script. To get around this, I was thinking I could use hiRegTimer() to close this dialog box automatically but I couldn't find the handle (symbol name) for it.
    Any idea will be appreciated, I really hope there's a way to get this done otherwise the use of this streamout from memory feature will be very limited.
    I don't think this is possible, because it's not a SKILL dialog box. I think an enhancement request to provide a template option (or similar) to control whether the dialog box is displayed or not would be a sensible idea - so you'll need to contact Customer Support to ask for this.
