  3. How to convert integer to string?
  • Replies 18
  • Subscribers 154
  • Views 47844
latha
latha over 16 years ago
Can anybody let me know skill the function how to convert integer to string?
Ex: a=123 (integer)
I need
a="123" (string)
    Andrew Beckett over 16 years ago +1
    sprintf(a "%d" a)
  • jazzmatazz
    jazzmatazz over 10 years ago
    Hello all, good topic
    I would like also to use a conversion of string to symbol in such a way but something is not ok.
           a=stringToSymbol("opt1")
           b=stringToSymbol("opt2")
                       hiGetCurrentWindow()->a->b
    The received value  is nil ... but should not be. ("opt1" and "opt2" are just for example)
    How I can perform this operation?
            Nikolay
    Hi Nikolay,
    The -> operator does not evaluate the property name argument - it takes it literally. So this is looking for a property called "a" on the window, and then a property "b" on that.
    You'd have to use the get() function instead:
    get(get(hiGetCurrentWindow() a) b)
  • jazzmatazz
    Thanks Andrew,
          And what if the properties are in the body of the command
                           a=stringToSymbol("property1")
                            b=stringToSymbol("property2")
                                   command(property1->property2)
              Nikolay
    Nikolay,
    I have no idea what you mean by "the properties are in the body of a command". Please give a real example - this is a bit abstract at the moment and it's hard to understand what you're asking.
  • jazzmatazz
    Actually now I realize that this is not property , but it's argument for the command.
    The command is with syntax
     The question is how I can build this argument for proper evaluation
                                               command(a->b)
    And probably this question have to be moved to another topic :)
              Nikolay
    Nikolay,
    Your question still doesn't really make sense - it's still too abstract - but as a wild guess, maybe you want:
    command(get(symeval(a) b))
    Unless you give a real example though, I'm just stabbing in the dark here.
  • jazzmatazz
    Andrew,
       It's not needed to give you examples for the current issue, even with such abstracts description you managed to understand what I probably mean.
       Your proposal works perfect. Thanks!
              Nikolay
  • theopaone
    theopaone over 10 years ago
    As Andrew pointed out, the dash-arrow operator represents the get function. Your command string should be:
    command( get(a b))
    This will execute on the values of a and b rather than on a and b itself.
    Ted
