  3. Virtuoso / Skill: how to change access permissions to cells...
  • Subscribers 150
  • Views 21285
Virtuoso / Skill: how to change access permissions to cells?
StefanSL
StefanSL over 15 years ago
Dear all,
to avoid any changes to cells after a certain milestone, i want to remove the "write" attributes from the cells; this should be done by a script, not manually via the library-manager;
Is there a skill-function to achieve this? A ddSet...-equivalent of ddGetObjAccess seems not to exist;
System: virtuoso 6.1.3 on RHEL
When i do a "chmod a-w" on the terminal to the .oa-file of my layout-view, everything is fine, but when i'm calling "chmod  a-w ..." by a Skill-"system"-call, the cell gets locked and the lock is not released again. The .oa-file is changed, permissions are set as desired, but i can still open the cell in edit mode, it's just the other way round, virtuoso refuses to open it read-only and tells me it's already open in edit-mode.
Regarding file locking: when i'm opening a cell for editing, there are two lock-files generated, as expected mycellname.oa.cdslck and an additional file mycellname.cdslckRHEL....hostnameandsoon.
When the cellview is closed, both of them disappear.
After the chmod-system-call, these two files persist until virtuoso has been restarted.
clsAdminTool is not capable to release the lock, ddLockFree and associated commands fail too.
Any idea how to avoid the locking-problem and/or how to do the job of setting my cells to read-only by skill?
What about the concept itself, the cells need to be accessible but protected, adding cells to the library is required;
is this approach sufficiently safe?
kind regards, many thanks
Stefan
    Stefan,
    The fundamental problem is that you must still have them open for edit, either in the current session or in another session.
    If you did:
    editableCellViews=setof(cellView dbGetOpenCellViews() cellView~>mode!="r")
    And then you could filter this to only be the ones you want to change the permissions on. Before changing them do:
    foreach(cellView editableCellViews dbPurge(cellView))
    or
    foreach(cellView editableCellViews dbReopen(cellView "r"))
    You might want to do something to save them maybe. You could use part of the code here http://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:ViewSolution;solutionNumber=11026354 to prompt the user to save any unsaved cellViews.
    If you've purged them and they're no longer editable, then the locks will go. Then it's safe to change the permissions. There's no SKILL API to change the permissions though.
  • pcardoso73
    pcardoso73 over 13 years ago
     I am sorry to put a question 2 years  after Andrew's reply.
     I am using IC 6.1.4. I would like to know how to make cells read only by default within a certain Library.
    If I have, later, to get access to write permissions to one cell only, is it enough to do "Make Editable "? Re-opening the cell will it open as read only again (I would like this to happen) ?
    Best regards,
    Pedro Cardoso
    Pedro,
    Make Editable will not alter the file permissions on disk. It just means that if you opened it read only in the tool, it will then reopen it in edit mode - but will only be able to do that if it has UNIX permissions to edit the cellView.
    You can use Edit->Access Permissions in the Library manager to alter the UNIX permissions.
