  3. Using the code the GUI uses
  • Replies 13
  • Views 22321
Michael Robinson
Michael Robinson over 16 years ago
Cadence GUI's are bulky and clunky. I want to drive the behind-the-scenes code that Cadence GUI's drive.
For example, le0ViaForm. I can set the variables that are used in the form: le0ViaForm->viaMode->value="Stack" from skill.
But those variables don't exist until the form is called at least once. So the first time my skill is run, it errors.
Once the form has been initialized (manually), using the form variables is difficult because of Cadence's 'unreal time' timing.
Yes, I know about hiRegTimer. That's a kludge.
Driving the inputs to a GUI from Skill is like yelling at a driver on the freeway going 70mph to change lanes.
How can I access to the real code behind the GUI's? Where is the reference to the code behind the GUI's?
     I respectfully disagree. They're different operations. I can see cases where you might want to select a section of a track, and the entire via stack at the end of that segment.
    Since it's an icon on the screen, or a bindkey, it's not exactly a "fat" GUI...
    Still, everyone is entitled to their view point! Some customers wanted these to be separate - they can't be both separate and combined...
  • dmay
    dmay over 15 years ago
    Cadence's flexibility with Skill code makes this so you can have it if you want it by creating your own bindkey:
     geTogglePartialSelect() hiGetCurrentWindow()~>viaStackSelection = !hiGetCurrentWindow()~>partialSelect
    Put this on your F4 bindkey and you get what you want. If I don't want it I don't have to add it.
    Derek
  • Michael Robinson
    Michael Robinson over 15 years ago
     Derek,
    Well done.
    Setting the values into the current window property is subtelty I've not seen before.
