  3. Hierarchically Layer generation
  • Replies 25
  • Subscribers 152
  • Views 28384
gparasiliti
gparasiliti over 15 years ago
I need to generate a layer starting from other layers placed hierarchicaly in my layout, I used "layer generation" from layout menu but it works only in the cellview, I tried using skill commands but I don't know how I can get all layers from the instances placed in my cellview, off course my layout has many pcell placed.
Grazie,
Giuseppe
  • stalapatra
    stalapatra over 10 years ago
    Hi Quek,
    With the following data I am getting some issues. For all the cases the outLayer is having some issue, and not accepting the user input.
    Can you please suggest the correct way to use the function?
    CCShierLayerOps(?cv geGetEditCellView() ?layer1 list("pp" "drawing") ?outLayer list("vtl_n" "drawing") ?op "GROW BY" ?size 1 ?level 1)
    CCShierLayerOps(?cv geGetEditCellView() ?layer1 list("pp" "drawing") ?layer2 list("nw" "drawing") ?outLayer list("vtl_n" "drawing") ?op "AND" ?size nil ?level 1)
    CCShierLayerOps(?cv geGetEditCellView() ?layer1 list("pp" "drawing") ?layer2 list("nw" "drawing") ?outLayer list("metal2" "drawing") ?op "AND" ?size nil ?level 1)
    CCShierLayerOps(?cv geGetEditCellView() ?layer1 list("via1" "drawing") ?layer2 list("metal1" "drawing") ?outLayer list("metal2" "drawing") ?op "AND" ?size nil ?level 1)
    Error Messages::
    *WARNING* (TECH-2000192): dbLayerSize: Invalid layer/purpose - ("vtl_n" "drawing").
    nil
    *WARNING* (TECH-2000192): dbLayerAnd: Invalid layer/purpose - ("vtl_n" "drawing").
    nil
    *WARNING* (TECH-2000192): dbLayerAnd: Invalid layer/purpose - ("metal2" "drawing").
    nil
    nil
    Subhabrata
  • skillUser
    skillUser over 10 years ago
    Hi Subhabrata,
    Are you sure that you are using the correct name for the layers?  The layer names are case sensitive, e.g. is it "Metal2" instead of "metal2" ?  You can verify the names in SKILL if you aren't too sure, something like:
    tf = techGetTechFile(geGetEditCellView())
    setof(lp tf~>lps lp~>purpose=="drawing")~>name
    => (... "M1" "VIA1" "M2" "VIA2" "M3" "VIA3" "M4" ...)
    Hopefully this helps you?
    Best regards,
    Lawrence.
  • Quek
    Quek over 10 years ago
    Hi Subhabrata
    You might want to continue the discussion in this new thread which you had created and not in this old thread.
    Best regards
    Quek
  • stalapatra
    Thanks, Lawrence. That worked.
    To utilize the same function I was even looking for the queries following the thread community.cadence.com/.../1348118.
    Where I wanted to read the hierarchy first and place the generated layers in there individual hierarchies, in place of adding the generated layers at the top level.
    I was looking for the suggestions with reference to the CCShierLayerOps procedure call. Here is the sample that I was trying to use:
    procedure(CreateLayerHier(libName viewName inputLay1 inputLay2 outLayer opt size level @optional listOfCells)
    let((cv libId cellId cellList)
    libId = ddGetObj(libName)
    if(!listOfCells then
    cellList = libId~>cells
    else
    cellList = nil
    foreach(cellName listOfCells
    cellId = ddGetObj(libName cellName)
    cellList = append(list(cellId) cellList)
    );end foreach
    );end if
    foreach(cell cellList
    foreach(view cell~>views
    ;; using views matching viewName variable.
    if(view~>name == viewName && (cv = dbOpenCellViewByType(libName cell->name
    view~>name "" "a")) then
    printf("\nOpened view %L from cell %L of library %L for edit.\n"
    cv~>viewName cv~>cellName cv~>libName)
    foreach(shape cv~>shapes
    if((shape~>objType!="textDisplay" && shape~>objType!="inst" && shape~>objType!="path") then
    printf("\n Creating the layer %L. " outLayer )
    CCShierLayerOps(?cv geGetEditCellView() "inputLay1" "inputLay2" "outLayer" "opt" "size" "level")
    );end if
    );end foreach
    dbSave(cv)
    dbClose(cv)
    );end if
    );end foreach view
    );end foreach cell
    Thank you for the support.
    Subhabrata
  • stalapatra
    HI,
    I am waiting for the reply of my previous mail.
    As well I want to check, how I can block the generation of the layer, if the ouLayer is already placed based on the reference layer.
    Please let me know.
    Thanks for your support.
    Subhabrata
