  3. time delay in simple program
  • Replies 12
  • Subscribers 152
  • Views 21983
bloodwayn
bloodwayn over 15 years ago
i have a little time problem. i've wrote a program which creates in an area a specific numbers of rectangles ... so it begins in the left buttom corner, creates rectangles on the buttom to the right until the end of the area(with a while loop). after this, with an other while loop i jump up one line. in this line the first while loop makes his work again. and so on until the area is full of rectangles.
so this works in principle. but when the procedure jump in the second line it starts to become extremly slowley. and it doesn't matter how many rectangles are created.
so i can't understand why it becomes so slowely when the program starts the same procedure for a second time.
regards
Philip
p.s.: this is only a short extract out of my program. so in the same time where a rectangle will be created, it creates a new cellview which will be opened an closed again.
  • bloodwayn
     ah sry. i was going to send the code too.
    http://nopaste.info/77b4fd4fd2.html
    Philip,
    Any reason why you can't upload the code to this forum rather than posting a link to a site where you're showing the code with line numbers (means anyone would have to do a lot of editing to properly understand it or try it out to see what is going on)?
    Use the Options tab when posting a message if you want to attach a file.
