  3. How to access pcell instance co-ordinates from within Pcell...
  • Replies 11
  • Views 22004
How to access pcell instance co-ordinates from within Pcell code.
Jameel
Jameel over 15 years ago
Hi, Is there a way to find out the co-ordinates of the pcell instance from within the pcell code? Say for example, I want to create a pcell that prints a label showing the co-ordinates of the where the pcell is placed. within the code of the pcell I can create the label at the origin but i need to know the co-ordinates of the pcell instance in order to print the label. One way of doing this would be to pass the co-ordinate of the pcell instance as parameters, but am not sure if this is the correct way to do it. Thanks, -Jameel
  • Jameel
    Thanks Andrew. You are the expert.
    I missed the part about the .cdsinit during streamout in your previous post.
    The libInit.il works perfect!
    -Jameel
