  3. Fast access to hierarchy shapes
  • Views 7536
Slawa
Slawa over 14 years ago
Hello
How quickly to get access to shapes being deeply in hierarchy of design (or design areas). Now I use such algorithm:
inst_area=dbProduceOverlapInst(dbDes list(list(box_x1 box_y1) list(box_x2 box_y2)))
foreach(inst inst_area
dbFlattenInst(inst 10))
all_shapes=dbGetOverlaps(dbDes list(list(box_x1 box_y1) list(box_x2 box_y2)))
  But probably there should be faster mode. Flattening of each instance separately in the big project causes huge losses of time
Slawa
  • Austin CAD Guy
    Austin CAD Guy over 14 years ago
     Hi Slawa
    dbGet...Overlap... functions all have an argument that you can specifiy the hierarchy levels to search. Rather than flatten the instances try:
    allShapes = dbGetTrueOverlaps( dbDes list(list(box_x1 box_y1) list(box_x2 box_y2))) t 0:32 t )
    This finds all the instances, mosaics and shapes that intersect the bounding box in the levels from 0 to 32. The final t returns the array row and column information so you can transform the data.
    Note that the hierarchical data is returned as a list for each hierarchical element. The final ID in that list is the shape. The points of that shape are in local coordinates for its cellView that you have to transform to get the points in your current cellView. To do this, use dbTransformPoint in a loop. In IC615 you can use the new command dbGetHierPathTransform to get the final transform, otherwise you have to build up the transform with dbConcatTransform at each level of the hierarchy.
    Ted
  • deep242003
    deep242003 over 13 years ago
    Hi Ted,
    Is there a way to get only id of instances and mosiacs (no layers) hierarchial which can be processed further?
    P:S :  similar to summary but hierarchial data (0:32)
  • deep242003
    used function
    dbProduceOverLapInst(). but it doesnt gives hierarchial data .. only current level
