  3. How to change via level with skill in IC6
  • Replies 31
  • Subscribers 156
  • Views 36858
Eric L14
Eric L14 over 15 years ago
 In IC6, I have a bindkey which change via level (via1 to via2) . Main part of the code is:
; Current selected via
viaToBeChanged=car(geGetSelSet())
; new via identifier
newVia=dbOpenCellViewByType( technName viaName "layout" nil "r")
if( newVia then
  viaToBeChanged~>master=newVia
Do you know how doing the same thing in IC6 ?
Thanks in advance
Eric
  • kpai
    kpai over 15 years ago
    Thanks Andrew!    It works like a charm now.
    -Kathy =)
  • Gurup
    Gurup over 14 years ago
      Is there anyway to change the existing via rows or column, by using viadefs parameter
    No. You can't do that (it doesn't make sense either).
    You can change the rows and columns of an existing via instance by using:
    viaInst~>cutRows=4
    viaInst~>cutColumns=6
    or you could use dbReplaceProp() or dbReplacePropList() to change them in one go.
    You'll find that you'll get a different viaHeader if you do this - it will bind that via to a different header.
  • Gurup
    Thanks Andrew,I will try this.
    can you tell me what is difference between the objects and instances.
    Not sure I entirely understand the question, because it's like asking for the difference between fruit and apples.
    In both CDB and OpenAccess, various things are represented as "objects" in the database. For example, there are objects to represent shapes (e.g. rectangles, polygons, paths, ellipses etc), objects to represent instances, objects to represent nets, terminals, and so on and so on. Instances are a type of object. In CDB there was no specific object type for vias; vias were just instances. In OpenAccess however, instances are one type of object, and vias are another type - so there is now a specific object type for vias, thus separating them from ordinary instances (e.g. instances of devices, instances of other cellViews and so on).
    Hopefully that answers your question?
  • Gurup
    Thanks Andrew its working ..
    Please tell me the such similar command to change the via pitch, in one shot
    viaInst~>cutRows=4
    --Thanks & Regards
     Guru
  • Gurup
     Thanks  Andrew,for your nice ans  :-)
    Guru,
    You can find this information out yourself very easily. Place a via, and change the properties to what you want. For example, I altered the via width and length, and spacings. Then I did:
    car(getGetSelSet())~>viaHeader~>overrideParams
    and I get:
    (("cutWidth" 0.16)
        ("cutHeight" 0.17)
        ("cutRows" 3)
        ("cutColumns" 2)
        ("cutSpacing"
        (0.3 0.2)
    From this I can see that the spacing is controlled by cutSpacing, and similarly for the width and length (there's no "pitch", but obviously that's the width plus the horizontal spacing).
    Then I can do
    viaInst~>cutSpacing=list(0.6 0.4)
    viaInst~>cutWidth=0.25
    or whatever. You can use the same approach to find out the parameter names - try changing it interactively, then query the database to find out the names used.
  • Antonios
    Antonios over 13 years ago
    Dear Andrew,
    I am using your methododlogy to convert cdb instance vias to oa stdVias with dbCreateVia.
    The issue is that my pcells having conditional inclusions of vias do not work any longer. I must recreate them.
    Is there an easy way to update the pcell information with the new via objects?
     Antonios
     Antonios,
    I don't really understand your question.
