  3. How to change via level with skill in IC6
  • Replies 31
  • Subscribers 156
  • Views 36881
Eric L14
Eric L14 over 15 years ago
 In IC6, I have a bindkey which change via level (via1 to via2) . Main part of the code is:
; Current selected via
viaToBeChanged=car(geGetSelSet())
; new via identifier
newVia=dbOpenCellViewByType( technName viaName "layout" nil "r")
if( newVia then
  viaToBeChanged~>master=newVia
Do you know how doing the same thing in IC6 ?
Thanks in advance
Eric
  • Guruprasad S
    Guruprasad S over 11 years ago
    Hi ,
    I have written code to change Via 1 to Via X (X=2,3,4,5,6,7,8)
    here Metal M1 to M6 have common width and spacing , top 3 Metals that are FA, 3A , LB are having different width and space rule .
    my code works fine till V5 , after that V6 ie.  connects M6 OT FA , FA 3T 3A , 3A VV LB  here der is via spacing error . its taking same spacing rule as for M1 V1 M2 etc .
    procedure(viachange1()
    a=geGetSelSet()
    cvId= geGetEditCellView()
    vias = geGetSelSet()
    leReplace(cvId vias list(list("via definition" "==" "M1V1M2")))
    hiSetBindKey("Layout" "alt<key>KP_1" "viachange1()")
    procedure(viachange2()
    a=geGetSelSet()
    leReplace(cvId vias list(list("via definition" "==" "M2V2M3")))
    hiSetBindKey("Layout" "alt<key>KP_2" "viachange2()")
    procedure(viachange3()
    a=geGetSelSet()
    leReplace(cvId vias list(list("via definition" "==" "M3V3M4")))
    hiSetBindKey("Layout" "alt<key>KP_3" "viachange3()")
    procedure(viachange4()
    a=geGetSelSet()
    leReplace(cvId vias list(list("via definition" "==" "M4V4M5")))
    hiSetBindKey("Layout" "alt<key>KP_4" "viachange4()")
    procedure(viachange5()
    a=geGetSelSet()
    leReplace(cvId vias list(list("via definition" "==" "M5V5M6")))
    hiSetBindKey("Layout" "alt<key>KP_5" "viachange5()")
    procedure(viachange6()
    a=geGetSelSet()
    leReplace(cvId vias list(list("via definition" "==" "M6OTFA")))
    hiSetBindKey("Layout" "alt<key>KP_6" "viachange6()")
    procedure(viachange7()
    a=geGetSelSet()
    leReplace(cvId vias list(list("via definition" "==" "FA3T3A")))
    hiSetBindKey("Layout" "alt<key>KP_7" "viachange7()")
    procedure(viachange8()
    a=geGetSelSet()
    leReplace(cvId vias list(list("via definition" "==" "3AVVLB")))
    hiSetBindKey("Layout" "alt<key>KP_8" "viachange8()")
