  3. SKILL code to change text/net name in extract mode
  • Views 3276
Lior D
Lior D over 13 years ago
Hello all.
I've got extract view (for generating netlist from layout) generated by Synopsys StarRC.
There is a problem, which causes certain net names to be uppercase (when in the layout and in the subcircuit interface are lowercase).
I want to find all net names in the extract view, and workaround the problem (by changing them to lowercase, via a certain flow).
Trying to find labels, as done in layout view yielded 0 matches (using setof).
I am using IC 6.1.5 500.7
Any feedback is more than welcome.
-Lior
    Lior,
    You could do something along these lines (completely untested, but shows the principles maybe):
    foreach(net cv~>nets
      newNet=dbMakeNet(cv lowerCase(net~>name)
      dbMergeNet(newNet net)
    dbSetConnCurrent(cv)
    Note there is no checks in here to see if the new net exists already - so if you're creating shorts (might want to use dbCreateNet instead of dbMakeNet).
    Also, I suspect the problem is really that you need the terminals to be renamed, not the nets. Terminals are more straightforward, as you can just change the names of the terminals directly:
    foreach(term cv~>terminals term~>name=lowerCase(term~>name))
  • Venky20
    Venky20 over 12 years ago
    I am  a new SKILL user and would appreciate some help with regards to a problem i have. Basically i wanted to change all terminal names to lower case in all levels of my design, and i did try the above code snippet and it worked great for the cellview which was open. Could you kindly advise on how it can be done for all levels of a design, just by opening the top-level schematic view? A code snippet would be great.
    Venkatesh
