  3. How to set the order of a PCell's Parameters?
  • Replies 12
  • Views 7646
aakhavan
aakhavan over 14 years ago
In Cadence 5, the order of the pcells parameters in the Create Instance form was set by the order of the parameters in the pcDefinePCell function. However, using the same code in Cadence 6.1.5 results in the parameters being in a seemingly arbitrary order in the Create Instance form. Has anyone experienced this or found a work around?
  • sandeepc
    sandeepc over 13 years ago
     Even if we use CDF , we cant get the parameters in a particluar order?
    Sandeep.
    Sandeep,
    If you use CDF you can have them in whatever order you want. Have you tried? If so, what precisely is your problem?
