  3. Help on menu's
  • Views 958
Help on menu's
venuuuuu
venuuuuu over 13 years ago
 hi all,
          I had created two menus FPStools and FPSoptions. When iam going to hierarchy level then FPtools is appears two times and FPSoptions doesnot appear on the banner. What's the problem.  Iam using the verson 5141 and my codes are below.
           procedure(AmitAddMenu10(_args)
  let( (item1 item2 item3 item4 item5 item6 item7 item8 item9 item10)
    ;; create a couple of menu items
    item1 = hiCreateMenuItem( ?name 'item1 ?itemText "Layer Generation"
              ?callback "CCShiHierLayerOps()"
    item2 = hiCreateMenuItem( ?name 'item2 ?itemText "Automatically fixing Path Width"
              ?callback "path()"
       item3 = hiCreateMenuItem( ?name 'item3 ?itemText "Routing"
              ?callback "venurout()"
       item4=hiCreateMenuItem( ?name 'item4 ?itemText "create via in box"
         ?callback "contact1()"
            ) ;venu() is a procedure which i did not shown here
    ;; create a menu that includes the menu items and return a list of the
    ;; pulldown menus
item5 = hiCreateMenuItem( ?name 'item5 ?itemText "Change labels in bus"
              ?callback "labelChange()"
  item6 = hiCreateMenuItem( ?name 'item6 ?itemText "magic ruler"
              ?callback "")
  item7 = hiCreateMenuItem( ?name 'item7 ?itemText "half ruler"
              ?callback "CCScreateRuler()")
  item10 = hiCreateMenuItem( ?name 'item10 ?itemText "test visible & invisible"
              ?callback "textDisplays()")
    list(hiCreatePulldownMenu('AmitMenu "FPSoptions" list(item1 item2 item3 item4 item5 item6 item7 item10 )))
  );let
); procedure
;; create a userMenuTrigger trigger that automatically adds the menu
deRegUserTriggers("maskLayoutXL" nil 'AmitAddMenu10)
deRegUserTriggers("maskLayout" nil 'AmitAddMenu10)
  procedure(AmitAddMenu3(_args)
    item1 = hiCreateMenuItem( ?name 'item1 ?itemText "Assign labels for every instances"
              ?callback "labels()"
            );labels() is a procedure which ididn't shown here
    item2 = hiCreateMenuItem( ?name 'item2 ?itemText "Create Bus"
              ?callback "bus()"
       ; AB - this was item2 in the code as posted on the forum.
       ; so was obscuring the item2 above.
       item3 = hiCreateMenuItem( ?name 'item3 ?itemText "Present layers"
              ?callback "venu()"
       item4=hiCreateMenuItem( ?name 'item4 ?itemText "substrate contacts"              ?callback "substrate()"
    ;; pulldown menus
item5 = hiCreateMenuItem( ?name 'item5 ?itemText "Object information "
              ?callback "displayinfo()"
  item6 = hiCreateMenuItem( ?name 'item6 ?itemText "Object information off"
              ?callback "CCSobjInfoOFF()")
  item7 = hiCreateMenuItem( ?name 'item7 ?itemText "hierarchy library check"
              ?callback "TrlibraryReport()")
  item10 = hiCreateMenuItem( ?name 'item10 ?itemText "hierarchy Views check"
              ?callback "TrviewReport()")
   item8 = hiCreateMenuItem( ?name 'item8 ?itemText "Pin label Change"
              ?callback "CCSchangeLabelDelimiter(cv)")
 item9 = hiCreateMenuItem( ?name 'item9 ?itemText "Bindkeys"
              ?callback "bindkeys()")
    list(hiCreatePulldownMenu('AmitMenu "FPStools" list(item1 item2 item3 item4 item5 item7 item10 item8 item9)))
  );let
); procedure
deRegUserTriggers("maskLayoutXL" nil 'AmitAddMenu3)
deRegUserTriggers("maskLayout" nil 'AmitAddMenu3)
    I've not tried your code as I'm only on a handheld device right now, but the problem is almost certainly due to the fact that you've given ?name 'AmitMenu for both hiCreatePulldownMenu calls. Since the ?name is the name of the variable used to store the menu data, the second call will overwrite the first.
    So you need to give them unique names.
    Also, usually one would avoid recreating the menu each time by doing:
    procedure(myMenuTrigger(args)
    unless(boundp('myMenuName)
    ; function that creates myMenuName
    myCreateMenuFunction()
    list(myMenuName)
    This second thing is just a suggestion on how you can further improve the code.
