  3. Evaluating VAR through skill
  • Views 14463
adeuser777
adeuser777 over 13 years ago
I have a variable that retrieves stop time from ADE-L or ADE-XL session. Based on that I do some post processing. This flow breaks if user sets the stop time as a variable like VAR("stoptime").
This is what I am trying to do.
-          Open ADE-L, set transient stop time to 1u.
-          In CIW, type
                  a = asiGetCurrentSession()
b = a~>data~>analysis~>data~>tran~>data~>fields~>data~>stop~>value
-          This should return “1u”
-          In my code, I do something like,
if(evalstring(b) < 50e-09 then <do something>
-          This flow works perfectly fine.
-          Now, set stop time to  VAR(“stoptime”) and execute the above commands. “b” will retuns something like "VAR(\"stoptime\")"
-          evalstring(b) returns nil for this case and hence the entire code breaks.
Is there a way to handle this scenario?
Thanks.
  • adeuser777
    I see this issue only in ADE-XL. If I set a default value for “stoptime” in ADE test editor window, then evalstring(b) returns the correct value. However, if I delete the default value in ADE test editor window, and specify its value only in Global Variables section, then evalstring(b) returns nil.
    Please suggest a way to solve this problem.
    Thanks!
    Retrieving the variable value using this method (which involves accessing internal undocumented data structures) is unlikely to be reliable, and wouldn't work anyway if you were trying to sweep the variable value in ADE XL.
    If this is for post-processing (i.e. doing something after the simulation has finished), can you not just use VAR("stoptime") in your resulting post-processing expression?
