  3. Assigning key/value pair in disembodied property list
  • Replies 12
  • Subscribers 148
  • Views 11104
dNora
dNora over 14 years ago
I'm trying to create key/value pair and add it to the disembodied property list using loop. But it doesn't work as expected.
file2 = infile(f2)
pList = '(nil) ;; initiate disembodied property list
while(gets(sname2 file2)
   List2 = parseString(sname2)
   str = nth(0 List2)
   printf("pList->\"%s\"=%s\n" str str)
   pList->"str" = nth(0 List2)
);while
pList
close(file2)
This is output on CIW window:
port:"test_lmap"
pList->"nwel"=nwel
pList->"L71"=L71
pList->"ndif"=ndif
pList->"pwel"=pwel
t
(nil str "pwel")
t
As you can see key name is str not it's value. I tried to assign key as pList->strcat(nth(0 List2)) but I get parser error.
Is there any way to make it work?
Nora
    Andrew Beckett over 7 years ago in reply to zssfred
    Hi Fred,
    Hash tables are good when you have lots of completely variable keys; defstruct is good when you have a small number of fixed keys (it's actually implemented as an array under the hood, with a DPL for any non-predefined keys). So defstruct takes less memory and the lookup is reasonable when you have a small number of keys - less efficient if you use non-predefined keys.
    A lot of it boils down to style though - defstructs are more of a specific object than a hash table which is a more general purpose key-value pair storage mechanism.
  • zssfred
    zssfred over 7 years ago in reply to Andrew Beckett
    Andrew,
    I understand.
    Thank you.
    Fred
