  3. How to set axis label by ocean?
  • Views 16264
MatthewM
MatthewM over 13 years ago
Hi Everyone,
 Do you have any idea on how to set/change axis label by ocean? I went through the ocean user reference, but only found funcion changing windows/subwin title, lable curve etc.
what I want to do is after plot, use some function to change the x-axis or y-axis name to a specific one?
Thanks a lot!
    The axis label is set from the units on the traces plotted.  This is covered in solution 11609072 .
    However, you can also use awvSetXAxisLabel or awvSetYAxisLabel :
    awvSetXAxisLabel(currentWindow() "WhatIWant")
  • MatthewM
    Thanks a lot, Andrew!! It works great. BTW, how I can find those function description?? My current ocean reference is "June 2004, Production Version 5.1.41".
    Search in cdsdoc (or use the Help menus inside icfb) and search for awvSetXAxisLabel. You'll find it's in <ICinstDir>/doc/skartistref/skartistref.pdf
  • MatthewM
    Thanks a lot!! Just got it in SKILL reference manual. I really appreciate your help!
