  3. overlay plotting problem
  • Views 14665
MatthewM
MatthewM over 13 years ago
Hi There, I have a problem about overlay plotting by ocean script, my code is like this: ==================================== w = newWindow(); foreach( var varlist list1 = ... list2 = ... awvPlotList( w list(list1) list2) ) ==================================== basically I want to plot a bunch of curve on the same window, but it seems that the awvPlotList will erase the previous plot. I noticed that in ADE, we can change the plotting mode to append, is there any corresponding ocean function to achieve this? I google it but got nothing. Any idea to solve this? Thanks a lot!
    Which version are you using? I just tried in IC615 (latest hotfix), and each call to awvPlotList appends to the previous results.
    Rather than me testing in every possible version, could you let me know what getVersion(t) returns?
  • MatthewM
    Hi Andrew, Thanks for your quick reply! currently I'm using 5.10.41.500.6.147. Regards, Matt
    Matthew,
    If you use the ?index argument to awvPlotList, you can get them to append. For example:
    w=newWindow()
    awvPlotList(w '((1 2 3) (8 7 6)) '(4 5 6) ?index list(1 2))
    awvPlotList(w '((8 2 5) (7 9 5)) '(4 5 6) ?index list(3 4))
    In other words, make sure you use a unique index for each trace you're plotting.
    I tried this in  5.10.41.500.6.151 with both AWD and wavescan as the waveform tools.
  • MatthewM
    Andrew, Thanks a lot! it works like a charm! I really appreciate your quick and professional help. Best Regards, Matt
