  3. ADE - L and ADE-XL trigger
  • Replies 7
  • Views 4684
tyanata
tyanata over 13 years ago
I want certain function to be executed when ADE-L or ADE-XL is opened.
So I accomplished that using the following approach:
if( isCallable('deRegUserTriggers) then
    foreach(mapcar appInfo deGetAppInfo("schematic")->subTypes
        if(appInfo->viewType == "adegxl-schematic" then
            deRegUserTriggers("adexl-schematic" nil nil 'func_name)
        );if
            deRegUserTriggers("adegxl-schematic" nil nil 'func_name)
        );if
        if(appInfo->viewType == "analogArtist-schematic" then
            deRegUserTriggers("analogArtist-schematic" nil nil 'func_name)
        );if
    );foreach
But unfortunately it copes only the situation when ADE-L and ADE-XL are opened from the schematic window. When they are opened directly from the Library Manager this approach is not useful.
I found in the sourcelink documentation other trigger wich may be will be useful:
ddRegTrigger( "PreObjAccess" 'func_name )
But could not find example of its use.
Could some body help me on this issue?
Thanks in advance!
     For ADE L, the only public way is to use the following cdsenv:
     asimenv.startup sessInitTrigFunc        string  ""
    This function will get called when ADE L starts. I just did a search in cdnshelp for sessInitTrigFunc - unfortunately the example there is wrong (it talks about putting a function in the .cdsenv - and that's just incorrect - sorry. I'll file a CCR to get that corrected).  But here's an example.
    For ADE XL you can use axlSessionRegisterCreationCallback(). You can also use deRegUserTriggers with "adexl" as the viewType. The axlSessionRegisterCreationCallback is normally used when you then want to use axlSessionConnect to register callbacks on certain ADE XL events, whereas the deRegUserTriggers I would use if I wanted to customize the UI
  • tyanata
     Thanks Andrew!
     Using the definition: asimenv.startup sessInitTrigFunc        string  "" ,   solves my proble.
    Best regards,
    tyanata
  • ShrikantTI
    ShrikantTI over 12 years ago
    I have another questions on similar lines. Like we have dbRegPostSaveTrigger("Test1") and dbRegSaveTrigger("Test2") for all the schematic and layout databases, do we have similar functions for ADE save state.
    we need to register trigger function to save state of custom tool along with the artist state. Please do let me know if you have any other method how we achieve it.
    Shrikant
    Shrikant,
    Please contact customer support - I don't believe there's a public trigger to do this.
  • Matth83
    Matth83 over 12 years ago
    Hi Andrew, everyone,
    Continuing the thread with my own experience : I registered one and the same trigger on the 'Save' menus of ADE L and XL doing:
    In .cdsinit :
    load "CheckLockADESaveMenu.il"
    envSetVal("asimenv.startup" "sessInitTrigFunc" 'string "customCheckLockPostInstallTrigger") ;# for ADE L
    CheckLockADESaveMenu.il is (in short):
    ;####### Setting callback
    define(customCheckLockPostInstallTrigger(args)
       w_window = hiGetCurrentWindow() ;# for ADE L states, window cannot be fetched through (args->window)
        l = parseString(hiGetWinObjName(w_window))
        newLib = nth(length(l)-3 l)
        newCell = nth(length(l)-2 l)
        newView = nth(length(l)-1 l)
        l_bM_handle = eval(cadr(hiGetBannerMenus(w_window))) ;# handle to the 'File' banner, containing the 'Save' menu
        if(pcreMatchp("adexl" newView) then
          hiSetMenuItemCallback(l_bM_handle 'saveFileItem "CheckLockADE_XLSaveMenu(newLib newCell newView nil)")
        else ;# state is ADE L
          hiSetMenuItemCallback(l_bM_handle 'SaveState "CheckLockADE_LSaveMenu(newLib newCell newView nil)")
    ;####### Triggers registration
    deRegUserTriggers("adestate" nil nil 'customCheckLockPostInstallTrigger)
    deRegUserTriggers("adexl" nil nil 'customCheckLockPostInstallTrigger)
    ;####### ADE L & XL callbacks
    procedure(CheckLockADE_LSaveMenu(newLib newCell newView exit) ...)
    procedure(CheckLockADE_XLSaveMenu(newLib newCell newView exit) ...)
    All works well on the triggers side, I get my callbacks executed prior to saving with both ADE L and XL... However, whenever opening an ADE XL view and starting a job over corners, I get the job pending. Whereas double-clicking on the test, opening the test editor, the job runs.
    Interestingly enough, when restarting virtuoso commenting out the "sessInitTrigFunc" call in my .cdsinit, my ADE XL simulation works... but of course, the ADE L doesn't trigger on 'save' anymore. I don't think axlSessionRegisterCreationCallback() would help me there for ADE XL but I might be wrong.
    I wonder if this is because I use only 1 trigger for both tools, or if I don't use the correct trigger types (adestate and adexl) or if there's something more to it... in any case, I can't fathom the reason why, so your guess/feedback would be much appreciated!
    Thanks & Regards,
    Matthieu
    PS : I use Virtuoso 6.1.5.
    PPS : ADE XL job distribution method is Local, not LBS
  • Matth83
    Hi All,
     I've found the error in the ADE XL job's log when the jobs are pending:
    \e *Error* Error during configuration of remote session.
    \e ("hiGetWinObjName" 0 t nil ("*Error* hiGetWinObjName: argument #1 should be a window type (type template = \"w\")" nil))
    So, somehow, the hiGetWinObjName() doesn't work on the hiGetCurrentWindow() at ADE XL start-up. Could it be that it loads each test window in a session window and that it doesn't work at beginning since there's no hiGetCurrentWindow() yet?
    Doesn't explain why it works when not calling the ADE L init triggers tough...
    Anyway, I've added a condition "when(w_window then ... )" and it finally works for both ADE L and XL.
    Thanks anyway,
    Kind regards,
    Matthieu
    Matthieu,
    I think the issue is probably because ADE XL initializes sessions for each test, but does so without a window - so almost certainly it's because your code is assuming that there's a window.
    BTW, the deRegUserTriggers on adestate is probably not doing anything, because ADE L is not a "DE" application.
